TDA7498 ebay strange output levels
TDA7498 ebay strange output levels [Problem solved]
Hi
I've been building an active speaker with a TDA7498 amp from ebay:
http://www.diyaudio.com/forums/multi-way/271951-el-cheapo-active-loudspeaker-5.html
The amp-module is the cheapest one from ebay:
100W High Power 100W Class D Amplifier Board DC20V to DC36V TDA7498 | eBay
The amp works, but measuring the output levels of the bridges I got some odd results.
PSU was approx 32V (lab psu, stable). One half of each bridge did approx 25Vpp into 8Ohm without visible distortion on a scope, but the other half does only approx 15Vpp at the same time.
This goes for both channels on the board and for two boards purchased 6weeks apart.
Is this normal operation for a TDA7498?
EDIT: Problem is solved. See page 2.
Hi
yes it is,,,,
just google full bridge configuration(full bridge amplifier,H bridge)
Hi.
Thanks for the answers.
I understand how a bridge-amp works and the amp-board in question do indeed use a virtual GND. Input is referred to Vss.
But that stilll dosnt explain my findings. No matter what reference-point we use, the two halves of a bridge should output about the same level PP. The two signal are 180 deg out of phase, but approx the same level pp. Otherwise one half will clip before the other and output-level becomes lower than expected.
@Doctormord: If the bootstrap-voltages was sagging, then both parts of the bridge should be equally effected yes?
@Mike: Cheap; yes. Fast? Not so much. I'm not blaming the seller. Just being curious and trying to improve. Part of the Ebay-thing is getting the parts to actually work :).
Do you have any input on the OT?
@Nigel: If the virtual GND was not at the correct potential, then both parts of the bridge should be affected?
Kind regards TroelsM
Would guess, theres something wrong with the caps at volume level. Have a measure for the caps in the working brigde compared to the not working one and see if they capacitance differs.
Quick and easy, change all bs-caps to known working ones with the right capacitance.
OK, My point is that if you buy something that is TOO inexpensive for what it claims to be, either it is of inferior quality, design or was derived from slave labor. I dislike all three possibilities.
Mike
Mike
It is a personal choice. No one should force you to change and you should not impress your opinion on others, either directly or indirectly.
Let's stay on the topic.
I found the error. It was more stupid and obvious than I had expected.
In this thread there is some discussions about these modules:
http://www.diyaudio.com/forums/class-d/265387-ebay-cheap-tda7498-boards-9.html
It turns out that the manufacturer have implemented the RC-damper in the output very poorly. Wrong actually. - or at least in a way I dont understand.
The 2.2Ohm resistor is NOT part of the RC, but in series with the output....
This explains the asymmetric output voltages and the lack of bass that some people have reported.
So 2 solutions: 1)Short out the 2.2 resistor. 2) pull out the capacitor and the resistor and implement the the RC correct. Both versions work. Approx the same residual noise on the output.
TroelsM
Input and ground hookup
Hello,
I just got this very amp written about here.
When facing the front/volume pot there is a jack for the inputs.
Are the lugs (from left to right).... Left RCA, ground of the RCA's, Right RCA?
I searched around all the eBay sellers, and don't see a diagram.
Thanks in advance whoever helps me,
Mark
On my TPA3116 it's RED/BLACK/WHITE.... Middle pin is ground
Some of the eBay pictures seem to show GND being the middle terminal.
The connector lead was supplied with the TPA3116 dual chip.
If you need leads or connectors, plenty of options on eBay. They are JST XH connectors. "Extension" cables all over eBay for "2S" RC battery packs.
Thanks Jerms,
I'm fiddling with the tpa7498 right now. I took the plunge and decided to try it. And the leads on that jack would indeed be as I guessed. When looking at the front/volume pot the jack leads or lugs from left to right will connect as follows:
Left RCA, middle is the ground, then Right RCA
Thanks for the tip on what those connector wires are known as. I could use some more of them. Now I know what to punch in the search bar on eBay.
Your help is appreciated!
Happy Sunday,
Mark
I got one of the tda7498 amps, am listening to it now in fact. And I really like it.
I'm using a 30vdc Cincon Electronics brand brick type supply, 3.3 amps.
Question: Could anyone point me towards a good, reasonably priced similar supply just in case this one should ever fail? I've searched Google, e-Bay, etc. and they seem difficult to locate.
Thanks in advance,
Mark
