Need help with iraudamp7d - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 19th June 2015, 07:19 AM   #1
Default Need help with iraudamp7d
i get only 120 watts in 8ohms and 100watts in 4ohms. all components and pcb is same as international rectifier.
what may be the issue?
thanks in advance
Old 19th June 2015, 08:37 AM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
How did you make the measurements and what power supply are you using?
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 19th June 2015, 10:19 AM   #3
i m using transformer rating +-50volts 3amp. built just one channel. i measured output voltage and waveform. i measure it again changing feedback resistor and now i get around 180wats at 4ohms. cant go further dont know why.. and also dc protection trips when using speaker. but on resistor load it works well.
i am using 2n5401 for dcp instead of 2n3906 as in iraudamp7d ref. design
Old 19th June 2015, 10:36 AM   #4
Send a message via Yahoo to ionutzxpo
"using transformer rating +-50volts 3amp" your answer is in front of you
Iacob Ionut
Old 19th June 2015, 12:34 PM   #5
Old 19th June 2015, 01:38 PM   #6
what about dc protection tripping?
Old 19th June 2015, 02:21 PM   #7
abraxalito's Avatar
You could trigger the DC protection from supply pumping I'd guess - your speaker's going to be inductive in the LF.
Old 20th June 2015, 10:15 AM   #8
ok.
How much wattage will this board will require to provide output of 250watts in 4ohms?
Old 20th June 2015, 10:26 AM   #9
abraxalito's Avatar
Do you mean 250watts average power on a sinewave ? If so that's 500W peak power (sine has 3dB crest factor) so your PSU's peak current delivery needs to be 11.2A. Its average will be considerably less.
Old 20th June 2015, 01:49 PM   #10
yes sine wave.
paralleling iraudamp7d sweetperfume Class D 4 3rd March 2015 07:59 AM
anyone from INDIA interested to buy iraudamp7d clones sweetperfume Class D 0 27th October 2014 06:11 PM
Copyright 1999-2017 diyAudio
