I was assembling a TPA3116 amp and when I went to put the knob on the volume pot, I noticed it was skewed to one side. I thought that I could just apply a little bit of pressure and straighten it out. I'm sure you know what happened next. SNAP! Now I have a broken vol pot. I've never changed or soldered a pot before, so I have 2 questions. 1) is it something I can reasonably do (I can solder) and 2) what pot do I get? Please provide a link if you can.
This is the board:
Yuan Jing Audio - ON SALE! - TPA3116 Class-D Stereo Amplifier Board [50W+50W] - USD $11.99 - Class-D & T
I'm not at home right now but I can disassemble the amp and take a closer look tonight.
Just looked at the pot in question. The only marking on the pot is 50K. It is attached to the PCB by 6 pins. I do have a Lepai 2020 board I use to salvage parts off of from time to time although I'm not sure how easy it would be to transplant the pot from one board to another.
This looks to be a replacement on their website. Yuan Jing Audio - JAPAN ALPS Potentiometer RK27 Series Stereo A50K-Ohm - USD $18.50
You could email them to verify.
- Class D
- Broken volume pot
