Guitar Mini Amp with PAM8610 Module - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 9th April 2015, 09:42 PM   #1
Default Guitar Mini Amp with PAM8610 Module
Hi Everyone,
I want to build a small guitar Amp, something like the ruby (Ruby) but I want more power. I have tried a PAM8610 based module (Mini Hi-Fi PAM8610 Audio Stereo Amplifier board/2X10W Dual Channel D Class 12V - from Alibaba.com), but the guitar pickups levels are too low to drive that module.
I know I need a preamp between the Guitar and the Amp Module, but I want something very simple but effective. Do you know some very simple circuit I can put in between? It should have at least 1M ohm Z to not load the guitar pickups and enough gain to drive the PAM module.
Thanks in advance
Old 10th April 2015, 01:53 AM   #2
Interesting topic! I'm working on the same type of project. I had the same issue with driving the 2x3W cheap amp I bought(I mean CHEAP lol $3).
I had a behrenger amp modeler stomp box laying around and it made the little amp scream. I ended up gutting it and installed it in the amp(cigar box). pretty sweet but I already want to build new one
I don't see any reason why you can't use the first stage of the Ruby as your pre.
There are some links here as well: preamp for guitar
Here's the amp board I used: Mini Digital 3W+3W Amplifier Module Board - Green
Surprisingly loud with the stomp box in the loop! And $3.09 a pop lmao!! Pics attaached.
My next amp will be a custom board using a TI TPA3112. I may try the FET preamp with that one.
Old 10th April 2015, 03:19 PM   #3
Your Amp looks very nice
The input stage of the Ruby will not work because it is just a buffer (gain=1) So it will bring a wonderful 1M Ohm input match, but no gain at all.
I want something really simple, maybe a JFET based input buffer (like ruby), followed by a bjt common emiter amplifier.
Guitar -> JFET Buffer -> BJT Amp -> Power Amp
Or something based on OpAmps:
Guitar -> OpAmp Buffer -> OpAmp Amplifier -> Power Amp
But I want the simplest solution.
Old 11th April 2015, 01:46 PM   #4
Thanks, yeah my sons are digging the little amp. I'm with you tho, I want more power
My bad on the ruby idea. I guess I already showed my low electronic knowledge lol. (which is why I'm spending a lot of time on this forum)
Have you checked any of these AMZ circuits out? The Muff Boost looks like it may do the trick.
Old 14th April 2015, 01:22 AM   #5
Yes, the Muff Boost looks great. Do you know the input Z of that?
Old 14th April 2015, 09:24 PM   #6
I don't know sorry. I believe it's a bit on the low side from what I've read. I'm planning on trying it soon, so will let you know how it works out.
I'm pretty you can raise the impedance by raising the value of R3. But, from what I understand, you will lose with that change.
Check out the circuit just above Muff, called mosfet boost. It's 10M Z and can be changed.(I may try this one too!)
PAM8610 Amp distortion jtron5 Class D 2 15th December 2014 10:29 PM
Mini PAM8610-gf1510 jwhisl Chip Amps 1 17th June 2014 09:07 AM
Mini AD815-based amp module Vidalgo Chip Amps 8 13th September 2006 04:12 PM
Mini guitar amp from a Webcor tape amp, is it possible? StiffHand Tubes / Valves 9 28th July 2006 01:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
