Discrete class D amplifier outputs low volume - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 2nd April 2015, 05:08 AM   #1
Default Discrete class D amplifier outputs low volume
Hello everyone,
I have a discrete class D project that I need help with but since I'm not an analog guy I got a problem. So far I got everything set up and the discrete class D works perfectly. But it outputs a low volume sound due to the DC voltage which is about 6 volts, if I increase the voltage I'll burn my circuit. So How do I increase the volume of the speaker so my circuit can handle up to 35V to get a high volume sound.
on the attachment is the schematic and simulation.
I'd appreciate tips and help.
Old 2nd April 2015, 10:08 AM   #2
Send a message via Yahoo to ionutzxpo
where is the feedback?
Iacob Ionut
Old 2nd April 2015, 10:31 AM   #3
I dont have a feedback, why I need it? And feeding back from where? Sorry I'm not expierened with analog circuits.
Old 2nd April 2015, 10:46 AM   #4
I don't have a feedback, why do I need it? I'm sorry I'm not experienced with analog circuits.
Old 2nd April 2015, 01:31 PM   #5
wwenze is offline wwenze  Singapore
Emitter resistor of Q1, it's missing.
Edit: Ok I see the shunt feedback via R2. But you still need the emitter resistor because it adds a way to control your DC point. Right now your purple waveform is stuck at -5.5V plus VBE of Q1.
Also your DC levels are all over the place. Pink and yellow (and/or purple, depending on how you do it) should have the same DC level.
Get the green waveform working first, then you can look at adding a post-filter feedback later too.
Also, try simulating with 0V input and audio frequency input first.
Simple 60dB discrete low noise amplifier (lna) iko Solid State 465 19th June 2014 06:04 AM
Fully Discrete Class D Amplifier (WIP) darkamikaze Class D 39 15th February 2013 07:29 PM
Class D at low volume levels mfong Class D 46 21st February 2010 11:17 AM
Discrete Class A amplifier for discussion. keantoken Solid State 11 17th January 2009 04:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
