brx2400.1d blown - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 21st March 2015, 07:27 PM   #1
jo282 is offline jo282  Canada
Default brx2400.1d blown
Hi, my hifonics brx2400.1d blown yesterday
I opened it up and 4 fets blown and a couple resistor near them burned. I do have soldering skill to change these no problem, but before I try I'd like to know what you guys think...
Would it work? And what else should I be looking for on the board?
Nothing else LOOKS burned or damaged, and I have a multimeter to check some components
Old 21st March 2015, 10:19 PM   #2
nigelwright7557's Avatar
You need to find out why they blew.
Simply replacing them might see them blow again straight away.
You could put a mains lamp in series with the amp before powering it up again.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 21st March 2015, 11:09 PM   #3
I had just installed 0 gauge wires from the old 4 gauge I was using. I suspect my voltage was too low. Could low voltage cause the fets to blow?
Anyway the day went by and I think I will just buy a better amp.
I don't want to speed any more money on a ******** burnt amp, my mtx 650 blew 2 months ago on the input IC because of a cheap line-out converter and now this one blew. So I want an amp that will last me longer.
Should I get the Crescendo BC2000D or is there something better for 500?
And how many battery and what brand should I get? (stock alt)
Old 23rd March 2015, 12:00 PM   #4
Check and drivers before them located in Vergata of izgorleite resistors. If everything is OK, replace rezitorite and Mosfet. Submit the amplification and in ammeter. Current of +12 volts at rest should not exceed 1.5-2!
If it is larger, obviously has a problem. Verify that no short after rectifying diode.
hifonics brz2400.1d oldschoolamp Solid State 0 14th March 2015 02:06 PM
Hifonics BRX2400.1D (Brutus BRX-2400.1D) Repair Ginks Car Audio 19 8th April 2014 03:00 PM
BRZ 1700.1d ian33 Car Audio 5 28th February 2013 12:55 AM
Atomic AT-5000.1D S Merlington Car Audio 20 24th January 2013 03:53 PM
autotek MM1000.1D xtremesound Class D 0 22nd February 2006 11:52 PM
Copyright 1999-2017 diyAudio
