Hypex UcD180HG mods list
Have you actually bypass the supply line on the module
& use a dedicated supply for HNR/HPR regs
Not yet but I plan to do that soon.
UCD400 has a preregulator before the HxR regulators.
It also serves to drop down the input voltage from around +-62V to around +-15V.
It is the entry point from the separate psu.
This is maybe more difficult to implement in a case of UCD180...
Yes I have some experience with UCD as well. Playing around with
caps around those pre regs changes the sound a lot. Was thinking
For my HG + HxR I can get even more perfomance if I give it a
dedicated supply. Think aux supply from smps is still better then
tap off onboard module supply. Besides we still can increase cap
capacity or upgrade those caps
Thanks again
It's up to you to decide and try. I think that aux supply is dedicated for auxiliary purposes, not to feed a high quality buffer.
Besides we still can increase cap capacity or upgrade those caps
I wouldn't increase the capacitance anywhere. Most often SMPSs do not require high capacitance.
Changing the capacitors in smps - maybe.
HxR dedicated power supply
Thanks again
Hi
In my next UcD amp I wll use an external input buffer but with HxR modules.
So I am really curious about your findings using a dedicated regulated power supply.
Please let me know?
