2.1 amp board with high pass? - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 23rd February 2015, 07:10 AM   #1
bcodemz is offline bcodemz  Canada
Default 2.1 amp board with high pass?
Can someone recommend a 2.1 board that has a high pass for the stereo channels? I really like the TPA3116 2.1 board, but apparently (and correct me if I'm wrong), it doesn't have a high pass filter for the stereo channels.
Thanks.
Old 23rd February 2015, 08:01 AM   #2
irribeo is offline irribeo  Netherlands
There always is a high pass filter on 3116 input, dc blocking caps and inputimpedance, like datasheet also mentions. If you reduce value of these 4 inputcaps you'll limit bass main channels are able to produce.
Old 23rd February 2015, 03:20 PM   #3
Could you explain further? If I high pass the input, then wouldn't there be no bass going into the amp at all?
Is there anything that I can read that'll teach me the various parts of an amplifier and what it does?
Old 23rd February 2015, 04:03 PM   #4
http://www.ti.com/lit/ds/symlink/tpa3116d2.pdf
page 14 for high pass, eg I use an amp with 100nF inputcaps, you can calculate what -3dB point should be
Old 23rd February 2015, 04:19 PM   #5
I'm actually a newbie when it comes to amps. Where can I read about all this stuff and educate myself of all this?
FS: Pass Zen Headphone Amp Assembled Board pftrvlr Swap Meet 1 24th March 2013 08:10 PM
FS:Dynaco PASS 2 pre-amp PCB board puremilk Vendor's Bazaar 0 23rd March 2013 04:14 AM
Need some help understanding high & low pass filters & crossovers Haz Multi-Way 13 12th May 2012 02:03 AM
variable Low-Cut, High-Pass & High-Cuts TobWen Solid State 3 14th September 2004 09:40 PM
Nelson PASS Bride of Zen Preamp Board Stuffed & Working AD Swap Meet 8 27th May 2004 08:54 AM
Copyright 1999-2017 diyAudio
