Problem with filtering in speaker amplifier - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 21st January 2015, 09:58 PM   #1
tigox is offline tigox  Portugal
Default Problem with filtering in speaker amplifier
Hello, i own the "supertooth Disco" portable speakers and lately am hearing a lot of nasty noise on the right channel, so after opening the speakers, i found a TPA3004d2, and started probing with my DS1054z oscilloscope; at first i didn' now how in the world i was going to see the waves because of how class d amplifiers work, but after AC coupling the inputs and enlarging the horizontal scale i found that there really is something up with the right channel:
Here is shown the left chanel in yellow and the right channel in blue, and as you can see there is major interference in the right(blue) channel.
After attempting to take a closer look at actual peak i zoomed in and got this:
So, as i am new to class d, my one and only guess is a bad filtering stage somewhere, maybe the LC filter at the output? or maybe a cap somewhere?
Opinions are appreciated
Old 21st January 2015, 11:02 PM   #2
nigelwright7557's Avatar
Try replacing the capacitor in the filter first.
That would be a cheap easy fix.
Old 21st January 2015, 11:10 PM   #3
which capacitor, input network, output?
Old 21st January 2015, 11:11 PM   #4
Output filter.
Old 21st January 2015, 11:16 PM   #5
Is your amplifier well decoupled ?
If it wasn't that would be a source of noise too.
I found class d to be fussy about decoupling and pcb layout.
Old 21st January 2015, 11:39 PM   #6
the amplifier is from a speaker system (supertooth disco) i am trying to repair the noise, so i would assume it is well decoupled, but yes i will check the output capacitor, and also, i am sorry to ask but are you referring to the decoupling cap or the LC filter?
Old 21st January 2015, 11:40 PM   #7
The LC output filter.
Old 21st January 2015, 11:46 PM   #8
thank you so much, tommorow i will try to replace it and will report back if any good result
Old 22nd January 2015, 11:23 AM   #9
So... I replaced the capacitors and the problem remains.. Hum, but also I got a better sound at what the noise sounds like, it sounds like the highs are there but the mids and low ends like bass distort, any ideas? And also what is the ideal way to measure the output of a class d on an oscilloscope?
Old 22nd January 2015, 03:09 PM   #10
doctormord's Avatar
There might be a problem at your input. Guessing, that INRN is coupled to GND via a capacitor, there might be a problem. The scope pics look like that. You may check that. (broken cap)
http://www.360customs.de
Power amplifier input stage psu filtering sajti Solid State 3 9th December 2014 01:50 PM
Driving headphone from speaker output - filtering layout Cordraconis Analog Line Level 6 3rd June 2014 04:24 PM
DC voltage on Output Speaker Arcam amplifier problem dazzz Solid State 8 25th January 2014 11:30 PM
AKAI AM-u2 amplifier problem no output on speaker. yash1 Solid State 0 30th December 2012 03:07 PM
Meridian M20 Active Speaker Amplifier Problem stellavox Solid State 1 24th October 2012 05:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
