TDA7492 vs TPA3116 Tests - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 26th December 2014, 07:32 PM   #1
rcbuck is offline rcbuck  United States
Default TDA7492 vs TPA3116 Tests
Has anyone purchased this item?:
http://www.ebay.com/itm/360982220650?_trksid=p2059210.m2749.l2649&ssPageNa me=STRK%3AMEBIDX%3AIT#ht_3500wt_1111
I purchased it and am disappointed in results obtained in testing. I used a 24 volt power supply, 6 ohm resistive load, and 1kHz sine wave input signal. The most voltage I could get out before clipping was 11.5 volts. This translates to only 22 watts.
I pulled the heatsink and right beside the chip the silk screen says TDA7498. However, the chip must actually be a TDA7492 chip. If I increase the power supply voltage to 29 volts the chip goes into shut down. This is the shut down voltage for the TDA7492 part.
I have this board from Parts Express:
http://www.parts-express.com/2x50w-tda7492-class-d-amplifier-board--320-301
With the same test conditions listed above, I can get 14.3 volts out before the amplifier goes into clipping. This translates to 34 watts which is much better than the board above.
As a comparison, I have this board:
http://www.ebay.com/itm/DC18V-24V-TPA3116-ClassD-Amplifier-Board-50W-50W-Filter-Capacitor-2-10000UF-/251413946728?pt=LH_DefaultDomain_0&hash=item3a8970 6168#ht_2780wt_1291
With the same test conditions, I can get 15 volts out before the amplifier goes into clipping. This translates to 37.5 watts which closely matches the power out versus power supply voltage curves for the TPA3116 part.
In all tests, I am only driving one channel. And I let the resistive load cool down between tests.
I have two questions:
1) Any guess as to why the first board will only put out 22 watts and the second board with the same part will put out 34 watts?
2) Is the TPA3116 part much better than the TDA7492 part? It will put out almost 3 extra watts under the same test conditions.
Old 26th December 2014, 07:48 PM   #2
irribeo is offline irribeo  Netherlands
Must be the 10.000uF capacitors
Parallel TDA7492? Tenson Class D 23 16th July 2014 12:12 AM
TK2050 vs TDA7492 eisp4nzer Class D 8 5th April 2014 05:12 AM
New Sure TDA7492 rikkio Class D 7 28th April 2013 08:17 PM
25W TDA7492 and 50W TDA7492 ??? Wieslaw Lipowsk Class D 2 17th March 2013 08:27 PM
TDA7492 baggins Chip Amps 5 26th November 2012 11:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
