Current sensing in CLASS-D - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 7th November 2014, 08:51 PM   #1
Default Current sensing in CLASS-D
I have a question... Has anybody measured the current of CLASS-D prior to LC filter directly at the PWM output? Has anybody seen any real advantage of measuring the speaker current in CLASS-D before the LC filter vs after the LC filter.
After the LC filter the common mode is not as bad as after the LC filter.
Old 8th November 2014, 12:38 AM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
It depends on what is going to be done with the current monitor signal.
For example, for cycle-by-cycle peak limiting purposes, sensing before the capacitor includes capacitor current to ensure the limit is not exceeded at high frequencies. But the cost effective evolution of this is sensing before the LC filter, across FET Rds-on, because "floating" sensing uses more parts (or requires "floating" power supply). An exampe of this implementation can be seen in IRS20957 FET driver IC datasheet (and there is an app-note too), although datasheets from this manufacturer are not particularly easy to understand.
For slower gain-reduction based current limiting, or speaker monitoring purposes, sensing after output capacitor tends to be easier. Sensing at speaker ground lead even easier, for single ended applications. Bridging requires some form of floating sense circuit and analog level shifting.
Another option that I have seen is an auxiliary winding in output inductor feeding an integrator, to reconstruct inductor current waveform, but to make this circuit accurate the integrator needs variable compensation depending on output inductor winding resistance, and copper resistance almost doubles from ambient temperature to approx. 100C, so implementation becomes complex and not very accurate.
I use to feel like the small child in The Emperor's New Clothes tale
Old 8th November 2014, 10:11 AM   #3
The advantage wll be less harmonics after the filter, what reduces heat in the sensing device.
Old 10th November 2014, 11:27 PM   #4
Thanks for your inputs... What is the harmonics needed for the current sense. Typically speakers have 1% linearity so how good should the linearity of the current sense should be... I guess this depends on the applications?
current sensing relay schematic? ojcool Car Audio 4 20th June 2008 04:42 PM
current sensing in series with anode resistors ErikdeBest Tubes / Valves 9 7th March 2007 11:26 AM
Help with SMPS current sensing Pierre Power Supplies 28 9th June 2005 03:31 PM
Current sensing circuit design help DC Dave Everything Else 5 21st April 2004 10:09 PM
Current-Sensing Servo Feedback BAM Multi-Way 1 24th February 2004 11:18 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
