Modifying PC power supplies?
Old 18th January 2004, 11:10 AM   #1
Optical is offline Optical  New Zealand
Default Modifying PC power supplies?
Does anyone have information on how you could modify a pc power supply to change the voltage levels?
I have a few around so if modifying them is possible then they could make good cheap supplies!
Old 18th January 2004, 11:48 AM   #2
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Here:http://www.bleedinedge.com/guides/ps...v_mod_pg1.html
And here:http://www.xtremesystems.org/forums/...threadid=16050
itīs a start
Old 18th January 2004, 11:53 AM   #3
Immo_G is offline Immo_G  Australia
I don't know if you get Silicon Chip magazine over there in NZ, but they did an article where they modded an IPEX standard 250 watt psu, and ended up with 13.8 V @ 25 A, which is a lot of power, but i guess for amp you'd want more voltage.
Old 18th January 2004, 02:22 PM   #4
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
well I do know how to get up to 30V on the 12V line...but I'm stumped about getting a negative voltage...anybody care to answer that??
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 18th January 2004, 02:52 PM   #5
SkinnyBoy is offline SkinnyBoy  Australia
Banned
Send a message via MSN to SkinnyBoy
yeah.. by connecting another rectifier diode and filter cap to the same winding, but in reverse..
Old 19th January 2004, 03:39 AM   #6
ok, thats a good start!
whats the max voltage that people have obtained?
i sortta just skim read all those links, i guess i'll find out for myself tonight when i read them properly..
Old 19th January 2004, 03:44 AM   #7
Banned
you're going to have to rewind the primary and secondary windings on the transformer... I believe.....
Old 19th January 2004, 03:54 AM   #8
Benjlv is offline Benjlv  United States
Send a message via Yahoo to Benjlv
these sypplys are nothing to mess with...the designs i have seen have had large input caps with one large mosfet doing the switching on the primary of the transformer. This means high voltages! can kill you. And if everything is not perfect in these devices the high voltage tends to conduct where you wouldnt think it would and bang!
anywho...Although it is possible. If youre going with a higher voltage you may need to replace the output caps to support that higher voltage. Also if you double the voltage output the current output in theory will be halfed.
The negative 12volt output and negative 5 volt on power supplys tend to be of the low current variety. Often just using a 7912 as a voltage regulator.
Old 19th January 2004, 09:09 AM   #9
li_gangyi's Avatar
yupz that's right the current will be halfed...and yes the -12V is provided by a 7912...
Old 19th January 2004, 10:50 AM   #10
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Exclamation Danger, Will Robinson!
Agreed. If you don't know the definitions of "basic insulation" and "reinforced insulation" then do yourself a favour and give it a big miss. This NOT meant to sound condescending, but it is not something you should feel your way through. One flash and you're ash.
/Circlotron - plays with audio stuff for fun, but is SMPS professional.
Not immune to electric shock either, BTW.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Modifying PC power supplies?Hide this!Advertise here!
JLH 80w mosfet power amplifier - modifying it Kevinbd Solid State 128 16th March 2017 04:41 PM
Parallel a dual power supply or two power supplies? Thunau Power Supplies 12 16th February 2007 04:21 AM
Modifying auto power on sensitivity? Sillyboy Parts 3 2nd July 2006 04:31 PM
Modifying preamp power supply Peter Daniel Pass Labs 5 2nd April 2002 09:48 PM
Regulated Power Supplies for Low Power Amps PTL60 Solid State 18 6th February 2002 06:24 AM
