Seeking Advice 12V 30-40w stereo amp with bluetooth built in - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 18th July 2014, 05:38 PM   #1
Default Seeking Advice 12V 30-40w stereo amp with bluetooth built in
I have been looking high and low for a Class D amp with built in bluetooth that will run off ~12V and output ~2x20W. I know that Arjen Helder (sp?) made some at some time but I cannot seem to find them anymore. I see plenty of wholesale options online, but that is not feasible for me. After much time and frustration, I found this TDA7491 based amp and have been in contact with the seller who has offered to sell me one for $16 (plus shipping). Any advice on this particular amp or other options would be much appreciated.
Old 25th July 2014, 02:44 PM   #2
Bump and an update. I ordered the amp in the link and Ill report back with my impressions. Still, no one knows any commercially available 12v amps with Bluetooth integrated?
Old 25th July 2014, 10:37 PM   #3
doctormord's Avatar
Interesting construction, im tuned in for your review.
(I wonder why someone would put the power-connector right beside the volume-pot)
http://www.360customs.de
Old 13th August 2014, 02:22 PM   #4
Wow, I'm sorry doctormord. I assumed no one was paying attention to my thread!
The amp has been very much a disappointment. The bluetooth range does not extend beyond 8-10 feet even after I cut the antenna and soldered a copper wire to the base. The seller has been very communicative but not very helpful. He/she said that he/she will send me a TA2020 based bluetooth amp at no cost... I think. The language barrier and extreme time difference have been pretty inhibitive.
I'm still open to any other suggestions people might have on a 2x20W bluetooth incorporated amp.
Old 26th August 2014, 03:38 PM   #5
The Supplier has been gracious enough to send me another amp. This one is... interesting, but it works well! The bluetooth range is as expected, ~10M. The layout is a little wonky but he assured me that this is a prototype. There is no pop and it has a nice, sizable 4400 uf, 25v output capacitor.
Ideally, Id prefer something with no whistles and bells (i.e. no LCD, card reader, FM radio, etc) to maximize efficiency and minimize size since I am looking for a strictly battery powered and portable solution. aptX audio would be important as well but Ill take what I can get. Pics below.
Old 26th August 2014, 03:47 PM   #6
Pics attached
Old 26th August 2014, 04:05 PM   #7
Haha wow, that's a pretty ghetto solution. That's just two seperate products strapped together on an experimenting print.
Old 13th February 2015, 08:48 PM   #8
That is EXACTLY what I need! just a 12V bluetooth input, two channel output amp! Can I somehow contact this person to buy one?
Old 13th February 2015, 09:32 PM   #9
xrk971 is online now xrk971  United States
xrk971's Avatar
$20
Online Shop YJ 24VDC 2.0 channel class D bluetooth 4.0 TPA3116 amplifier board 2*50W|Aliexpress Mobile
Old 14th February 2015, 07:19 AM   #10
Thanks for the quick reply, but that one is 24V, I want to use it in my car. I currently have a lepai lp-2020a+ but now I want to get rid of the aux wire to my phone, bought a cheap usb stick-bluetooth receiver and a 12v to 5v dc-dc converter off of ebay, but I'm now having ground loop noise since both the amp and bluetooth thing are using the same battery. I tried grounding the rca's but so far no luck. I also bought a ground loop isolator, but the only one they had is cheap and filters all the bass out.
Seeking troubleshooting advice for my first amp build. GiF Instruments and Amps 13 26th May 2014 10:53 AM
Seeking advice on Tube buffer / pre-amp zman01 Tubes / Valves 58 11th July 2012 04:45 PM
Leak Stereo 30+, Stereo 70 & Delta 70 (UK sale) Tweedle12 Swap Meet 2 13th April 2012 11:32 PM
40W class A push pull amp with JJ 2A3-40w possible? 3nity Tubes / Valves 18 26th May 2010 11:05 PM
12V to +&- 30 to 35VDC SMPS Miniature Nordic Power Supplies 4 7th January 2008 04:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
