Need help with IRS2092 Subwoofer Amp - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 4th July 2014, 04:08 PM   #1
Default Need help with IRS2092 Subwoofer Amp
I'm attempting to design a single sided PCB for a IRS2092 based class D amp with +/- 60V power supply Ive already made the power supply and protection circuits and only have the amp pcb's left to make, I've heard that this chip is very sensitive to layouts, so I uploaded my eagle cad files and pdfs of the circuit layouts and would really appreciate if I could have some assistance on improving the layout or some of the circuit values, I just don't want it to blow up the first time I build it . Its only for 4 ohm subwoofers so the switching frequency can be low. I need a little help selecting the deadtime and over current protection resistors. the FET I'm using it the FQA27N25, the 22uh inductor and 1uf film cap is going to be on a separate board above the switching mosfets thats why its not on the schematic yet, I'm going to wrap the inductor board in copper foil tape to reduce interference. any help would really be appreciated, thanks. Sorry for the messy eagle cad layout.
Inside the chassis now is the protection board (mosfet relay based), the soft start using MOV's, the capacitor bank and rectifiers, low current power supply (+/- 15V and 12V for the bias, and the 24db 100Hz low pass filter.
Old 4th July 2014, 05:25 PM   #2
Here is my sub's that the amp will be powering there Dayton Audio HF 12" in sealed box's and my sorta work bench.
Old 6th July 2014, 03:06 AM   #3
BUMP
Old 6th July 2014, 07:28 PM   #4
nigelwright7557's Avatar
The 2092 should be decoupled as close to its power pins as possible.
The whole layout should be as short and as tight as possible.
The output mosfets needs decoupling right next to the pins.
Your output mosfets look like they have too much gate capacitance 50nC,
I would use irfb4019 or irfb4020 which are about 20nC.
If you want to use higher power mosfets then you will probably need gate buffers, either npn/pnp or TC4420.
I always use max dead time to keep mosfets cool.
The over current protect needs adjusting to stop resetting at full power but at the same time protect against shorts.
Help needed with irs2092 amp robivitez Class D 2 19th December 2011 06:13 AM
IRS2092 Amp Design: Please help! Devendra Class D 11 17th March 2011 09:10 AM
Subwoofer with IRS2092 KlaRa54 Class D 0 12th October 2010 07:46 PM
Another amp with IRS2092 mag Class D 23 18th June 2010 07:25 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 02:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
