how to avoid bus pumping - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 3rd July 2014, 03:07 PM   #1
Default how to avoid bus pumping
I had bus pumping problem with my classdaudio sds-254, when playing some deep and punch bass, what would be a good way to avoid it, except turn volume down? right now I power it with connex SMPS300R, +/-45V, undersized I know, thinking to get a big one, like SMPS800RE, or go old way with 600VA transformer and some big caps, will it help? Thanks
Old 3rd July 2014, 03:39 PM   #2
big caps - the more the better
Old 3rd July 2014, 05:34 PM   #3
theAnonymous1's Avatar
An expensive option, but get another SDS-254 and run them BTL.
Old 3rd July 2014, 05:56 PM   #4
Running 2 in BTL would effectively half the impedance. this may or may not be good.
Old 3rd July 2014, 06:06 PM   #5
jcx is offline jcx  United States
I've seen that suggestion but don't understand it - "bus pumping" is the consequence of bidirectional power flow in switching output stages - energy stored in the speaker's mass/spring reactive components being returned to the PS during part of the output waveform
I don't see how bridging makes any difference in the basic power flow issue
if X Joules is stored in the moving cone mass then that X Joules gets returned to the PS Caps by the switching stages while decelerating the cone mass (with some reduction from <100% efficiency in switches and speaker)
I have definitely seen bus pumping in DC motor full bridge drives - had to explain to the Mech E why he blew up his drive electronics
https://www.google.com/#q=motor+brak...+dump+resistor
Old 3rd July 2014, 06:39 PM   #6
exactly, I have 4R speaker and sds-254 BTL is only good for 8R
Now another question, the 254 support both balanced and SE input, i'm using SE now, would balanced input make any difference?
Old 3rd July 2014, 06:44 PM   #7
Originally Posted by jcx View Post
I've seen that suggestion but don't understand it..
Here's a good explanation of bus pumping and why it doesn't exist for full-bridge (page 12)...
http://www.irf.com/technical-info/appnotes/an-1071.pdf
Old 3rd July 2014, 07:14 PM   #8
and that doesn't address the load energy storage at all - the example only talks about the switching inductor energy storage
my analysis is for load energy storage
Old 4th July 2014, 12:32 PM   #9
Check Tripath's application notes as well.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 4th July 2014, 02:48 PM   #10
Do you use it in bridge mode or in stereo mode ? ( should be no bus pumping in bridge mode) If in stereo mode reverse the input polarity of one channel ( with the jumper , one channel inverted and one channel non inverted ) and reverse the polarity of one of your speaker outputs ( put the - wire in the + output and vice versa ) and you should be fine .
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Sure IR2092 2x250W Overheating (plus bus pumping when idle) David_Web Class D 25 11th November 2013 10:33 AM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
what's up !? new choke=subsonic pumping nicoch58 Tubes / Valves 6 20th July 2010 12:41 PM
Bus pumping durwood Class D 9 16th April 2010 12:16 PM
Power Supply Pumping with full bridge edogd Class D 1 3rd February 2005 08:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
