Almost no sound - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 27th June 2014, 12:43 PM   #1
moldo2 is offline moldo2  Denmark
Default Almost no sound
Hello there
I have recently built a stereo for use at a festival. It's 12V driven by the Pioneer GM-D8604(GM-D8604 - Class FD 4-Channel Bridgeable Amplifier | Pioneer Electronics USA). The problem is however, that my hornloaded woofer(Fane International Ltd Loud Speakers) is almost silent. I would assume that as the amp can deliver 300W RMS(4 ohms) the woofer(8 ohms) would recieve about 150W RMS. Shouldn't that be enough to at least make quite a bit of sound? I am considering buying a mono-block amp beside the Pioneer just to power the sub. What do you think?
Old 27th June 2014, 03:29 PM   #2
Saturnus's Avatar
Maybe you should find out what you connected wrong or what settings you did wrong before buying more stuff
Old 29th June 2014, 12:45 AM   #3
nigelwright7557's Avatar
Originally Posted by moldo2 View Post
Hello there
Are you saying your supply voltage is 12 volts ?
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 29th June 2014, 08:16 AM   #4
doctordata's Avatar
Hello there
I'm assuming from reading the specs ,you are using the amp in Bridge mode .
You must have miss wired the speaker output or something .
Give it a try in normal ( non bridged mode on one channel) and see if it gives any output and if it does , have a look at the user manual how to connect your speaker and input in bridge mode .
Make sure your power supply can handle 33 Amps !
Cheers ,
Rens
If you measure, you know; if you guess, you don't
how to mix sound from notebook and external sound card and get headphones output burence73 Headphone Systems 17 29th December 2012 08:58 PM
Sony TA-VE215 cracking sound/sound cutting out crowdome Solid State 4 2nd October 2012 04:39 PM
Kicker zx700.5 sub channel has humming sound and amp2 has echo like sound ivkata Car Audio 3 10th April 2012 10:23 PM
The Ultimate Sound Improving for Compact Disc's through Patent-Pend.CD Sound Improver tiefbassuebertr Digital Source 145 25th April 2011 08:39 PM
Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns opc Swap Meet 6 1st May 2009 04:48 AM
Copyright 1999-2017 diyAudio
