Possible? digital in -> Behringer iNuke Possible? digital in -> Behringer iNuke - diyAudio
Old 1st June 2014, 02:04 PM   #1
Soldermizer is offline Soldermizer  United States
Soldermizer's Avatar
Default Possible? digital in -> Behringer iNuke
I am a -- mostly -- happy owner of several Behringer iNuke NUxxxx series amps (4 so far). I have had one fatality (a NU6000) in about three years of (ab-)use. I had modded it (quiet fans) and am not sure if that was a factor. But in any case...
As good a deal as the iNuke is, it does not have digital inputs. How easy, or is it even possible, would it be to route a digital input into the amp? First, let me say this is way above my capability to build or design. But seems like it would be a good project for you propeller heads here
So please, somebody build me one!
My waveguide is an Elated Obligatory Spheroid
Old 1st June 2014, 10:59 PM   #2
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
Unless it's a DSP version, it's all analog inside. Just put a DAC in front of it and call it a day.
Old 2nd June 2014, 02:49 AM   #3
Let us consider the DSP version ... What simple mod has been overlooked to out-Behringer Behringer?
Old 2nd June 2014, 01:41 PM   #4
gmarsh's Avatar
If it's a DSP version...
- take it apart, find the ADC chip for the audio input
- figure out the ADC data format - is it I2S output format, LJ/RJ DSP format, # of bits per frame, etc.
- disconnect the data line going from ADC->DSP, you'll be substituting your digital input here.
- figure out appropriate power supply rails, clocks, reset signals, etc that you'll need for the digital input circuit. You'll end up tapping resistors, vias, etc...
- knock a hole in the case for whatever data format you're feeding in, install a panel mount connector.
- bodge on a suitable digital input circuit.
Got a multichannel oscilloscope? You'll need it.
Old 4th June 2014, 03:06 AM   #5
I will keep it stock.
Possible? digital in -> Behringer iNukeHide this!Advertise here!
Behringer iNuke NU3000 w/o any fan...? Soldermizer Class D 157 11th January 2017 05:28 AM
Behringer iNuke 12000DSP (yes, that's THREE zeroes...) Brian Steele Subwoofers 8 17th October 2013 05:43 PM
HELP BEHRINGER 6000 iNUKE fAULTY Kol1 Class D 3 10th October 2013 10:38 PM
Behringer iNuke nu3000 Istong Class D 0 15th May 2013 07:34 AM
Driving a Behringer INuke Nu1000 slideman82 Tubes / Valves 0 31st August 2012 03:34 AM
Copyright ©1999-2017 diyAudio
