Stereo class d amp!
Stereo class d amp!
Old 31st May 2014, 03:10 PM   #1
kinter is offline kinter
Default Stereo class d amp!
hi to all.
i found this schematic on internet
and i made a stereo amplifier with the eagle cad
this is the pdf file for realize it!
schematic.pdf
Top.pdf
bottom.pdf
Old 31st May 2014, 04:32 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
OK, so how do you stop M1 and M2 switching on together at switch on?
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 31st May 2014, 04:37 PM   #3
I think the only solution is to use two n-channel mosfet, but the circuit should be modified to use an IR2110 .... this version uses complementary pairs
Old 2nd June 2014, 08:09 PM   #4
some time ago I made this from detex schematic
i realized a stereo version in a small pcb only 80x100mm, good quality and power, but i have some little problems at very low frequency...
The new version is better in schematic and layout!
Old 2nd June 2014, 09:41 PM   #5
voltwide is online now voltwide  Ireland
May be you will never encounter MOSFETs blowing up on power turn on - provided your power supply voltage does not rise too fast.
For that reason these kind of capacitive coupled PMOS/NMOS amps have a bad reputation of easily burning up, beeing more sensitive with higher supply voltage.
Stereo class d amp!Hide this!Advertise here!
Class D Stereo Amp in Mono? Jeff1971 Class D 23 23rd June 2014 04:05 AM
Stereo Class-D amp HIP4081 Whortless Class D 59 2nd February 2014 04:15 AM
FS: 2 x TDA8950TH Amp V2, Class-D stereo amp modules, (Connexelectronic) mrwireless Swap Meet 2 27th March 2013 12:14 AM
Class-T amp with subwoofer - impedance? mono or stereo? pdvrog Subwoofers 6 14th July 2008 06:04 PM
nrg control stereo class A amp jfrago Solid State 0 8th June 2007 05:41 AM
Copyright ©1999-2017 diyAudio
