tpa3116 newbie build question(s) - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 22nd April 2014, 05:48 PM   #1
Default tpa3116 newbie build question(s)
Ok. So I have been reading through the giant thread on this amp but I have not found what I am looking for yet.
I have the red board version and would like to remove the black power supply connector so that I can extend it when I put this into an case. Does it just pop off? Or is there soldering involved? Or is there a better way to do this?
Old 22nd April 2014, 07:53 PM   #2
The connector is soldered on. The easy solution is to leave the connector in place and solder power leads where the tabs for the connector stick through the bottom of the board.
Old 22nd April 2014, 08:19 PM   #3
Ok. That makes sense. I have seen this picture with the leads identified. But what kind of power cable do I attach to this? Do I just take a power cord and cut off the end and solder that?
Old 22nd April 2014, 08:24 PM   #4
I have also seen this pic on the Fleawatt site where he connects it to a connector mounted on the casing. How hard is this?
Old 22nd April 2014, 11:18 PM   #5
You need to provide 12-22V DC to these keeping the polarity in mind.
Old 23rd April 2014, 12:37 AM   #6
Lo_Tse is offline Lo_Tse  Canada
Comparing this picture to the one you took from Flea Watt, I think your polarity was not assigned properly.
Old 23rd April 2014, 08:35 PM   #7
The ground is at both points.
Old 23rd April 2014, 11:52 PM   #8
KJA,
That's what I thought. The two points that were marked + and - in the picture are actually both ground or -. So if one connect the two together, there will be no power. I was comparing it to the power connection shown in the picture from Fleawatt (post #4).
Old 23rd April 2014, 11:53 PM   #9
Oh, my bad. Now I see it.
TPA3116 Steampunk Amp cervelorider Swap Meet 16 1st February 2014 06:01 PM
TPA3116 in Hammond Chassis cervelorider Swap Meet 0 10th January 2014 02:14 AM
ebay TPA3116 2.1 amplifier tigox Class D 21 17th December 2013 04:54 PM
Help me build a TPA3116-based amp Big SturL Class D 5 11th September 2013 08:15 AM
Newbie question: Which gainclone should I build? hansolocg Chip Amps 8 11th January 2008 11:15 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
