I have got my hands on both an Amp4 and an Amp5 kit.
Support from 41hz seems to be dead, which i didn't realise at the time of placing the order. He still sells kits, but doesn't answer emails or provide any information on how to build them.
Can anyone help me out with assembly instructions for Amp4 & Amp5?
Thx
Thx
Thommy, I posted the AMP4 AI in this thread: http://www.diyaudio.com/forums/class-d/254989-41hz-amp4-assembly-schematics-needed.html
I have something, but it is not build tutorial. I think I had points, which you would follow, what to place first and so ondoes anybody have build tutorial for the amp7? Thanks!
anything, especially the schematic. Thanks!
Oh schematic, I have that, you are in luckanything, especially the schematic. Thanks!
For pictures, there is thread of mine here... and also you can see pictures from my site. And for any questions you have, I could check on the amp itself, top side anyway
PS5-B infos needed!
Hi there, had the bad idea to say a friend "yeah I can build a 41Hz kit to you".
Sadly at that time I was not aware of which nightmare I did step in...
So for now, as I got one rectifier, one TO92 and... that's all I wonder what is missing and what goes where.
First JP2 pins, I guess the 2 is +5V from HMute, but the second? 1 to the GND of the HMute led? No loop or such? or left open? (grounded seems).
The rectifier is the rectifier, D5 OK.
For R21 and R20 (100K and 1K), I have spare 1/4W metal, is it OK?
R100 is unknow... may start with 1K, no idea at all! Relays are Potter & Brumfield RTD14048 (good for audio?)
The single TO92 I have is BS170A, but is it Q1 or Q2 or both so have to buy one?
DZ1 just anyhting saying "zener 9V"?
How to make few parts annoying to death, 41Hz... @#!
Or maybe leave that away and let the speakers live a risky life
Thanks for any input guys!
Matthieu
ps: drawing from PS5-A but that is the same on B's.
Matthieu
Hi there, let's be optimistic and ask for help.
An happily used Truepath (TA3020) suddenly exhibit a loud buzzing noise wich cover more than half the music. In the meantime the overvoltage sense has become very sensitive to mains voltage change (linear psu).
Does that speak to someone? All voltage rails OK, unmute is fine for nomal mains voltage... but that buzzing wich come after say 1 sec and is not source volume related ( always loud ) and on both channel. No DC offset at all.
Or maybe the TA3020 does fry?
Matthieu
Matthieu
- Class D
- 41hz kits assembly instructions needed
