LF 41Hz AMP10 Basic assembly instructions - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 15th April 2014, 02:14 PM   #1
Default LF 41Hz AMP10 Basic assembly instructions
Hi all
I ordered and received an AMP10BASIC (41Hz Audio:AMP10-BASIC kit) from 41Hz Audio. It arrived in good time, but the forums are STILL down and I can't access the build instructions.
Several emails to the store owner have gone unanswered (but that seems to be the norm having done some searching).
Can anybody help out with instructions? I'm not confident enough to solder it based solely on the schematic.
Many thanks!
Old 16th April 2014, 02:10 PM   #2
Here You go.
I strongly suggest You modify the 5V according to the included circuit.
Also change c60 to a larger value (I used 470uF) and I recommend You use a input gain of 1.0 (22K for R3, R4, R43 & R44).
Good luck with Your build!
Old 16th April 2014, 02:21 PM   #3
Thank you thank you thank you!
Old 16th April 2014, 04:09 PM   #4
You're welcome
The reason for increasing c60 is to avoid turn-on "pops".
Replacing R100 with the above circuit avoids turn-off "pops" and gives a better regulated 5V.
Old 17th April 2014, 06:07 PM   #5
TitusTI is offline TitusTI  United States
Hey xrayspex: do you happen to have the assembly instructions for the regular Amp10 or Amp32 ? REALLY wish I'd copied those from the main page when I bought the amps last year...
Old 17th April 2014, 07:15 PM   #6
Sorry, nope.
Hope Jan gets the 41Hz-forum online again soon...
Old 17th April 2014, 07:25 PM   #7
Okay, well thanks anyway. The Amp10B ai you sent will give me something to work from for Amp10 so it's certainly better than nothing.
Yeah, I'm starting to wonder if the 41hz site will ever go back online...
Old 18th April 2014, 11:11 PM   #8
Alrighty, am almost done with the board stuffing, just a few of the larger caps and 2 resistors to go.
The assembly instructions say 47k for R43 and R44 if using a passive volume pot (which is what I'm doing). However, the kit came with 56k resistors for these locations. Will they still be okay?
Old 19th April 2014, 07:16 AM   #9
Personally I think you should aim for a lower input-gain since this amps input-protection is very sensitive. In my experience -1.0 is perfect even with a passive volume-pot. The chip-manufacturer recommends 20K/20K.
Old 22nd April 2014, 09:04 AM   #10
Alright, almost time to power up
However, there are no polarity indicators on the PCB for the power wiring, nor do the instructions mention it. Any advice?
41Hz AMP11 assembly instructions Jero Chip Amps 6 6th October 2014 09:58 AM
Amp-1 - 41hz assembly instructions needed MathKR Class D 0 19th February 2014 01:44 PM
41hz amp10-BASIC running in bridge mode DoctorLars Class D 0 14th February 2014 10:10 PM
Help with assembly instructions for 41hz amp6basic and Amp10 charly chile Class D 3 9th November 2012 11:38 PM
41hz Amp10 Basic Setup Issues raromachine Class D 5 15th March 2008 10:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
