Small SMPS problem - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 4th January 2004, 01:31 PM   #11
ddog is offline ddog  Finland
Originally posted by MaXiZ
It will die if it's power handling is exeeded. But don't worry, you have bigger than enough, it won't smoke.
Old 4th January 2004, 04:48 PM   #12
subwo1 is offline subwo1  United States
subwo1's Avatar
Make sure that R13, R14, VR1, C17, and C18, are all correctly placed into the circuit. The rest of the components at the bottom of the diagram are also very important.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 5th January 2004, 08:00 AM   #13
MaXiZ is offline MaXiZ  Italy
MaXiZ's Avatar
Send a message via ICQ to MaXiZ
sorry that was the correct image/shematic that i've used...
Andafter some further test i've seen that at thebridge the VOLTAGE is correct +/-33V but the current is low.. maybe awrong winding?
Old 5th January 2004, 12:00 PM   #14
How much current you can get out of that?
Old 5th January 2004, 12:12 PM   #15
MaXiZ's Avatar
after the bridge (not connected to the caps) i've measured around 1A... And as source i use a car battery (60A)...
The thing that is frustrating me is that i've already done one without any problem..
Do u need some photo?
Old 5th January 2004, 12:19 PM   #16
I don't actually _need_ photo, but it would be nice to see what your smps looks like, and it can help other guys help you. I'm building my first smps, it's almost ready, but i forgot to buy rectifier diodes, so it will take some time to get it working (nearest shop that sells suitable diodes is located 60km from my home)
Old 5th January 2004, 12:39 PM   #17
MaXiZ's Avatar
Both have the same problem
as primary 4wire of diameter of 0.5mm and as secondary 3wire of 0.5mm of diameter
Old 5th January 2004, 02:26 PM   #18
subwo1's Avatar
Looks pretty nice. I wonder if you just have some connection wrong somewhere and don't see it.
USMPS
Old 5th January 2004, 02:32 PM   #19
MaXiZ's Avatar
found...
I've connected the primary after the 56Ohm/5w resisotr.. really stupid and i've made lost time to all u! Sorry!
Simple 12V SMPS for small powered devices EWorkshop1708 Power Supplies 16 13th April 2008 10:46 PM
small smps with uc3844 Tekko Power Supplies 37 27th October 2006 03:08 PM
A small help on a SMPS MaXiZ Car Audio 3 1st August 2003 01:00 PM
Small Car SMPS needed.. deepanger Solid State 6 10th June 2003 01:48 PM
Rod's SMPS Problem fr0st Parts 9 15th March 2003 06:46 AM
Copyright 1999-2017 diyAudio
