Go Back   Home > Forums > Amplifiers > Class D
Old 7th March 2014, 12:22 AM   #1
Default Distortion at frequencies above 500Hz???
I have designed a class-d amplifier that will put out 20W into 8 ohms. This is for my own house.
I am lucky enough to have some very good audio test equipment at work namely the Audio Presicion ATS-2 and APx525.
The self-oscillating modulator is my own discrete design with a switching frequency varying from 400kHz to 700kHz. Opamps are OPA1612 and comparator is LT1711.
I am getting around 110dB SNR and around 0.002% distortion from 20 Hz up to 500 Hz.
At 500 Hz the problem starts. The distortion ramps up very quickly such that by 5 kHz the distortion is around 0.15%. This is very stark difference to 0.002%.
Long story short I am starting to suspect that the output filter that I am using is causing the distortion. I have gone over the modulator changing the filter corners and error amplifier / integrator gain. I have also tried multiple other op amps including the LM4562 and AD8620, But no matter what I do the ramp in distortion does not budge.
For this design it is my first time using this type of inductor: http://www.sagami-elec.co.jp/file/7G09B.pdf.
The filter capacitor is Film 150nF 100V: Panasonic / ECWU1154JC9
Output filter picture can be seen as attachment.
Does anybody here have experience with those Sagami inductors? Do they have problems at higher frequencies?
Maybe I am overlooking something else also. All comments are greatly appreciated.
Old 7th March 2014, 01:27 AM   #2
kevinkr's Avatar
This appears to be a common mode inductor, do you have both windings phased correctly, the schematic makes it appear they are reversed one relative to the other.. (I am assuming a bridged output.)
It's been more than a decade since I last worked on a class D amp, but the bridged ones I worked with did not use CM chokes, but had an independent diff mode choke on each output of the pair. The output filter is an integrator and I suspect the choke may not have enough differential inductance to do the job, probably a very sizeable amount of HF current in the caps.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 7th March 2014, 01:35 AM   #3
My understanding was that even though it is a single part it is actually two individual inductors (not coupled). I will contact sagami to verify this.
Old 7th March 2014, 02:42 AM   #4
Depending on the power level you're testing at this might be normal pre-filter feedback behaviour. Since you didn't post a THD versus power sweep for us to look at you might try comparing to, for example, figure 24 of the IRAUDAMP4A datasheet.
Old 7th March 2014, 12:07 PM   #5
I have both pre and post filter feedback. I will get these plots poster later today.
Old 7th March 2014, 09:38 PM   #6
I have posted some plots that i did earlier today with the audio analyzer. They should be self explanatory I guess.
Old 7th March 2014, 10:31 PM   #7
Khron is offline Khron  Romania
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
On a summary calculation, the cut-off frequency of your filter is about 90kHz - that's VERY high (especially for a self-oscillating amp). More common target frequencies are around half that.
2x 22uH + 330nF would put you around 42kHz.
Old 8th March 2014, 12:25 AM   #8
nigelwright7557's Avatar
I use separate t106-2 cores with as many turns as I can get on of 18SWG enamelled copper wire.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 8th March 2014, 01:44 AM   #9
Can you post a schematic too? Kinda hard to reason about this with only a partial schematic that's misleading for the parts of the design it does show.
Old 8th March 2014, 11:27 AM   #10
Here is the schematic.
Hammond B3 tech help needed. Distortion only on certain notes/drawbar frequencies. jasonguitar Tubes / Valves 7 2nd June 2011 03:51 PM
midbass 125hz to 500hz kornnylike Subwoofers 55 15th September 2010 11:36 PM
What about using a 18" until 500Hz? hugobors Multi-Way 28 14th September 2010 04:00 PM
Which Driver to use for 100hz-500hz? KCCT82 Multi-Way 27 6th January 2008 03:59 PM
Why don't/can't we use our (sub) woofers from 0 to ~500hz? JinMTVT Multi-Way 11 6th January 2006 04:26 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
