Digital Amplifier Project - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 3rd March 2014, 01:46 AM   #1
panson_hk's Avatar
Default Digital Amplifier Project
I am working on an commercial active speaker project that will use VIA VT1736 USB controller, TI TAS5548 audio processor and TAS5612LA class D output. I also want to make it available to the DIY world. Any comment?
Old 3rd March 2014, 07:43 PM   #2
doctormord's Avatar
Good!
Old 3rd March 2014, 08:27 PM   #3
Default Active speaker amplifier?
This could be a great amp for active speakers. It would be especially nice if the amp could be mounted to a plate for heatsinking, so the assembly could be mounted to the back of a speaker.
I've got a lot of working code for designing active speakers using the ST309 multichannel amp, and it wouldn't take much to adapt it to the TAS5548. I'd be glad to provide the firmware and software for this program or to collaborate in some way.
Old 16th March 2014, 01:05 AM   #4
I would be very interested in a board that has the TAS5548, I2S input, USB connection for control of the DSP parameters, an on-board MCU for interface and storage of DSP parameters, and an interface board that has SPDIF/AES/TOSLINK and volume control via IR
I think this may be too much to ask!
best regards,
Mike
Old 21st March 2014, 06:44 AM   #5
panson_hk's Avatar
Hi Neil,
Thanks for your comment and willing to do firmware. I look forward to having a join project.
Hi Mike,
Your suggestion is actually I am working after, more or less. The amp will accept multiple input both analog and digital.
Please see picture of the test board. The board does not have everything but 5548/5558 and 5612.
Panson
Old 21st March 2014, 10:22 AM   #6
panson_hk's Avatar
The amp section TAS5612 of the board is working. I use TAS5548 EVM to feed the PWM signals to TAS5612. I will populate the TAS5548 section next.
Old 22nd March 2014, 08:22 PM   #7
RAndyB is offline RAndyB  United Kingdom
I have been hoping for something just like this.
Andy
Old 28th March 2014, 08:26 AM   #8
panson_hk's Avatar
Here is my TAS5548+5612 board operating with an Arduino board being a host controller. Signal source is from VIA VT7136 USB audio streamer. I have tested it for 24-bit, 192 kHz.
foobar + upsampler, VIA ASIO driver, 5548 native 192 kHz processing.
Old 28th March 2014, 10:46 PM   #9
Very cool!
Quick question: Why the 5612LA?
(5612A seems to have slightly better performance.)
Mike
Old 29th March 2014, 07:55 AM   #10
panson_hk's Avatar
I looked for an older part (TAS5716) initially for single multiple channels. TI suggested 5612LA for new design as 5716 is "old". Now I can do high-power stereo.On the other hand, I need two 5612 for stereo active 2-way (full bridge).
One 5548 (96 k processing) can drive four 5612 (stereo, full bridge) for an active four-way project. What do you think?
Another project, all digital DDX amplifier hifimediy Vendor's Bazaar 462 21st June 2015 04:30 AM
Anyone interested in a digital amplifier project? Rookie Class D 552 24th September 2014 08:29 PM
Digital X-over project borges Multi-Way 9 4th July 2008 07:39 AM
Copyright 1999-2017 diyAudio
