Digital Amplifier Project
Old 4th April 2014, 01:50 AM   #21
mikey_audiogeek is offline mikey_audiogeek  New Zealand
Cool!
Yes, I have PurePath Console (PPC) GUI, I also have the PurePath Console Motherboard (as well as the TAS5548EVM).
Don't know if it helps, but the TI "Soundbar Reference Design" EVM includes code for the onboard MSP430 to load parameters/biquads as well as read RC5 IR and handle volume control, source switching etc. link here: PCM3070RHBEVM-K Evaluation Module - PCM3070RHBEVM-K - TI Tool Folder
Mike
Old 4th April 2014, 01:54 AM   #22
Discussion here: TAS5548EVM - device configuration on powerdown/powerup - Audio Amplifiers Forum - Audio Amplifiers - TI E2E Community
Mike
Old 8th April 2014, 02:51 AM   #23
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Default With miniDSP USBStreamer
Here is my PurePath digital amp with miniDSP USBStreamer.
Old 9th April 2014, 01:01 AM   #24
Nice!
Old 9th April 2014, 07:15 AM   #25
panson_hk's Avatar
Here are measured waveforms of the digital amp. The amp is powered by a regular 12 V SMPS. A 1 kHz of 2 Vrms was driving a 4 R load (USB to I2S done by USBStreamer). The output was connected to AP Portable One. THD+N was about 0.1 % (BW = 22 Hz to 22 kHz). Distortion residual is shown in the left picture below. Right picture shows 100 Hz distortion residual (THD = 0.022 %).
I will use AP-S1 to send digital signal to the board and get more data later including FFT of the output.
Old 11th April 2014, 03:51 AM   #26
panson_hk's Avatar
Default distortion residual
Distortion residual of two different output inductors are shown below. The inductors are Wurth high-current shielded SMD parts. For 22 uH, THD is 0.13% (1 W, 4 Ohm). For 10 uH, THD is 0.097 %. THD difference is not much at all. Distortion residual does show different shapes.
Left photo: 10 uH, middle photo: 22 uH
Filter capacitors: C80 = 2.2 uF (film), C82 and C83 = 1000 pF
File Type: png TAS5548_5612_12V_1kHz_1W_4R_10uH_2p2uF.png (27.8 KB, 339 views)
File Type: png TAS5548_5612_12V_1kHz_1W_4R_22uH_2p2uF.png (28.7 KB, 328 views)
Old 11th April 2014, 05:23 AM   #27
panson_hk's Avatar
If C80 is 1 uF with 10 uH inductors, THD is improved to 0.083 %. Interesting!
Distortion residual is shown below.
File Type: png TAS5548_5612_12V_1kHz_1W_4R_10uH_1uF.png (31.9 KB, 98 views)
Old 11th April 2014, 05:51 AM   #28
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
1uF is providing less attenuation of the carrier frequency, but equally means lower HF output current is drawn so I guess less stress on the output stage of the chip. A lower value cap might produce even lower THD... Try 220n?
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 11th April 2014, 07:15 AM   #29
panson_hk's Avatar
Yes, I will try lower capacitance.
Here is measured data just now. THD = 0.075 % for using two 22 uH in parallel for each output polarity. The cap is still 1 uF.
THD residual is shown below.
File Type: png TAS5548_5612_12V_1kHz_1W_4R_22uHx2_1uF.png (27.5 KB, 49 views)
Old 15th April 2014, 09:18 AM   #30
I'm running no output filter on my Purepath class D amps
The circuit board arrived today - thanks!
Mike
Digital Amplifier ProjectHide this!Advertise here!
Another project, all digital DDX amplifier hifimediy Vendor's Bazaar 462 21st June 2015 04:30 AM
Anyone interested in a digital amplifier project? Rookie Class D 552 24th September 2014 08:29 PM
Digital X-over project borges Multi-Way 9 4th July 2008 07:39 AM
