High-End Class D amplifier - 25w to 1250w with 2 N mosfets - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 11th February 2014, 09:09 PM   #1
johanx2 is offline johanx2  United States
Default High-End Class D amplifier - 25w to 1250w with 2 N mosfets
Hi guys, what do you think about this high end class D amplifier ? This amplifier design is making a lot of noise in a known Spanish forum, because of its high fidelity, very easy construction and amazing high power (25w to 1250w, even 12000w replacing certain components).
This is a work of José Tagle.
Source
Based on sorenson audio experiment (not UCD)
Components with DPN value should be ignored, they are for experimenting.
All resistors are 1/4w, unless otherwise specified.
Zener diodes are 1/2w
Power supply should be +/-40v (it should never exceed 50v)
To get 200w rms, the transformer should provide 10A
For this project, amazingly, mosfets don't really need heat sink, since they will be always cool, but just for precaution you can add two little 5w heat sinks.
Inductor depends on speaker impedance, for 4 ohms, inductor should be 47uh/10A, and for 8 ohms 100uh/5A. The designer says that there's no need for inductor only if we are feeding a subwoofer.
If you rather want less than 200w rms power, then you can feed the circuit with a lower voltaje, and then you should read the voltaje of TL074, if it's lower than +/-5.1v, half R21 and R22 values.
Old 12th February 2014, 01:43 AM   #2
Workhorse's Avatar
Where is the output Inductor and filter capacitor ??????
Old 12th February 2014, 01:51 AM   #3
andrewlebon's Avatar
Hi Workhorse
greetings whats best core for output for class d amps
warm regards
andrew
[image][/image]"It's Better to try and fail than to never know and always wonder"
Old 12th February 2014, 02:01 AM   #4
Amplificador HighEnd Clase D de 25W a 1250Wrms sólo con 2 MosFets N
UCD amp thread started here
Old 12th February 2014, 03:14 AM   #5
ishiru is offline ishiru  Indonesia
ishiru's Avatar
strange..how they works?..
isn't class D using modulator or whatever its name like IRF2110 or else for the simplest circuit?..and also, class D output was square wave and using LC is must for the output afaik.
Old 12th February 2014, 03:17 AM   #6
Give me 5 minutes to translate the schematic notes.
Old 12th February 2014, 03:57 AM   #7
The schematic mentions an output inductor, but none is shown as being part of the circuit... maybe it is located off of the pcb? That would make for a nice RF strobe...
Old 9th March 2014, 03:49 PM   #8
sivan_and's Avatar
Send a message via Yahoo to sivan_and
Anyone has gerber files for the pcb ?
SivanandBalan
Old 11th March 2014, 12:44 PM   #9
ljm_ljm is offline ljm_ljm  China
Who can have the oscilloscope test photos.
Square wave, or other?
Old 11th March 2014, 01:29 PM   #10
what is the c1 c2 r24 dnp
The High-End, how Hi-End is this amplifier board? (Ebay) Mihkus Solid State 4 24th June 2013 04:57 PM
FS: Eleven 2x TPA3123, 25W x 4 Class-D Amplifier Modules Applesauce Swap Meet 3 1st May 2013 01:12 AM
813 RCA amplifier - 25w, class A1, single ended,2 tubes,Rout~1ohm audiodesign Tubes / Valves 5 19th September 2010 07:34 PM
lateral mosfets in high end amplifiers sparkle Solid State 17 10th May 2007 12:30 PM
Class A high-end amp? lagoausente Solid State 6 4th February 2002 07:03 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
