Go Back   Home > Forums > Amplifiers > Class D
Old 5th February 2014, 03:25 PM   #1
mhtplsh is offline mhtplsh  India
Default Sure Electronics Class D Digital 250W IRS2092 Amp problem
I tried to connect the kit of IRS2092 Class D Digital 250W.
We had used a transformer of 63V DC and used a capacitor of 7000uFd each channel
We did not get a clear sine wave signal showing us a big hum in the output
As you can see from the picture the sine wave output of the the amplifier.
The measured output of the amplifier at 8ohms load was 32V
So 32x32/8 - 128W
Why am i getting such low output.
Not getting a clear sine wave output
Kindly help me in this matter
Old 6th February 2014, 06:32 PM   #2
uglykid is offline uglykid  Denmark
hi.
if you use the supply connections in the posted schematic its wrong. here is the right connection of a dual supply.
Old 7th February 2014, 03:19 AM   #3
Yes, my schematics is wrong.
It was drawn in hurry.
Now let me know what is problem with sinewave?
Old 7th February 2014, 08:44 PM   #4
nigelwright7557's Avatar
1/ Your power supply circuit is wrong.
2/ I could be wrong but it looks like there is some residual carrier on the output. That is normal (ish) and I wouldn't worry about it.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 7th February 2014, 11:52 PM   #5
DUG is offline DUG  Canada
Set the trigger level on the scope near the peak level and increase sweep speed (decrease sweep time).
Then you can see what frequency is modulating your sine wave.
As Nigel says, the scope can see the carrier but your ears can't hear it.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 8th February 2014, 12:17 AM   #6
RCBandwidth's Avatar
MHTP:
If you could provide some photos of the wiring(take a few) It might be helpful in diagnosing your problem.Please measure the +/- voltage to the input of the board and post result.
Have you hooked up to a Speaker system?...Does the hum increase with volume level?
One man's magic is another man's engineering.
Old 15th February 2014, 02:52 PM   #7
Originally Posted by RCBandwidth View Post
MHTP:
Dear
Here is the actual connection diagram of our setup. Waiting for your suggestions.
Sure Electronics IRS2092 250wpc Amp Build redjr Class D 49 15th January 2014 12:50 PM
Sure Electronics 2x300W (TAS5630) & 2x250W (IRS2092) killa12222 Class D 33 16th December 2013 09:14 AM
Just bought a TDA8950TH 2.1 digital Class D Amplifier Board 2*150W+250W (AM160) Chip2786 Power Supplies 4 1st May 2013 09:02 PM
which subwoofer for 250W@4ohms class D amp ? FroggySeven Subwoofers 37 29th July 2012 06:40 PM
Class-D Amp with IRS2092 mag Class D 185 24th February 2012 03:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
