Bigger SMPS hurts sound quality? - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 7th December 2013, 06:59 PM   #1
AC439 is offline AC439  United States
Question Bigger SMPS hurts sound quality?
I modded and listen to a Sure TK2050 board for a while. The tank caps on the board was replaced with 2x2200uF ROE gold caps with 2.2uF film cap in parallel. The SMPS was a 19v 2.4A Dell Laptop power supply and I knew from day one it is underrated. I have also added another 15000uF stiffener cap external to the board. It was OK overall, only thing I wanted more is bass due to the weak laptop supply.
I finally did the last thing on the list, which is to put a much bigger SMPS. Got a 24V 10A SMPS from the amazon. To my big surprise, first thing I noticed after the PS swap was obvious stronger bass with great low frequency extension. But the Tripath magic was gone. Resolution, depth and sound stage somehow dropped. The amp sounded like some kind of low distortion class AB transistor amp. I did read the threads about preference on stiffener caps or not so I yanked the 15000uF cap. The magic came back but the bass extension has also been dropped back to the previous level similar to with the laptop supply.
I'd wonder the stiffener cap is not the cause of the problem but, rather, a combination of the power supply's internal resistance, the ESR of the stiffener cap, tank caps on the board and even the circuit board layout on the power trunk.
Any thoughts ? ideas ?
Old 9th December 2013, 03:06 AM   #2
Please don't randomly connect Capacitors to the SMPS. It involves lots of calculations. Also the laptop charger you used is designed totally different, that can not cater the need of audio amplifier. I would request you to read the basic of SMPS designs.
You haven't mentioned what speakers are you using, ie single driver or two way or three way. with increase in low frequency two way and single driver speakers tent to lose the details on sound.
To understand this I would say. Use car battery in series to generate 24 V (for testing) . Use thick power cable. and keep it short as possible.
There is always a first time....
Old 9th December 2013, 03:17 AM   #3
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I reckon the bigger SMPSU is a stronger source of common-mode noise. Sure, its giving you stiffer rails but the CM noise is polluting your audio. You need some way to break the noise loop - perhaps an input trafo or a much more effective CM choke on the mains input.
Yes to using the car battery, a great solution. But not in conjunction with a SMPSU, on its own. Isolating the amp supply from the mains will clean up the noise issues considerably.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 9th December 2013, 03:24 AM   #4
Sorry, didn't put it correctly,
I meant use two car batteries in series with each other to get 24V. Not to connect it to SMPS when testing with battery.
Moreover if the SMPS is regulated. it has its own correction oscillations, that varies with load. although in most cases it hardly matters.
Old 9th December 2013, 03:31 AM   #5
abraxalito's Avatar
Ah yep - but two in series might be a bit high voltage? A car battery fresh off the charger is around 14V so will 28V be a bit on the high side? Myself I'd suggest 3 6V ones in series - at least that's what I plan to try out for myself.
Old 9th December 2013, 03:35 AM   #6
msb64 is offline msb64  Canada
Consider running a torroid transformer and filter module instead.
I ran that on my class D amp it sounds great, no shortage of bass at all.
Old 9th December 2013, 03:45 AM   #7
abraxalito's Avatar
Toroid will be lower noise than a switcher, but probably EI core (preferably split bobbin) will be better still. Toroids have fairly high interwinding capacitance so couple more mains-borne noise in.
Old 9th December 2013, 05:33 AM   #8
Thanks for all ideas.
I'm well awared of the SMPS design and the effects of adding a stiffener cap can throw off the PS. But I tend to agree that the increased in bass has degrade the details in sound. I'm well awared of the insufficient of the power rating of the laptop supply that's why I'm saying I just changed it out.
I like the idea of increasing the filtering mechanism from SMPS to the amp board, and try out batteries. I used to run a TA2024 off a car battery but I didn't notice much difference with using SMPS. I may be getting a toroid tranny to build a linear supply too.
I do want to try out a meanwell SMPS since for some reasons they are used for class D amps a lot.
Old 9th December 2013, 07:56 AM   #9
abraxalito's Avatar
I've been using an 18V Meanwell for my (class AB) chip amp. It works fine but needed more filtering (both common-mode and differential mode) than I first imagined to get the best SQ.
Old 11th December 2013, 01:17 PM   #10
I had a little bit of time yesterday so I played around in between the SMPS and the amp board. I think I might have identified the issue of being too much EMI or noise coming from the no name SMPS. The smaller laptop SMPS seems giving less noise therefore not affecting the sound of the amp as much as the bigger and stronger SMPS.
I did two things that seems to have bring back the magic:-
1) I added a 2.2uF file cap between v+/v- right at the output of the SMPS.
2) I twisted together the + and - wires going from the SMPS to the amp board. This pair of wires is just about 6 inches or so.
I keep the 15000uF stiffener cap at the location where the twisted power wires connects to the amp board.
It seems like filtering is the key here. Next I will try to add a C-L-C pi filtering network coming out of the SMPS to the amp.....
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
sound quality vs sound quantity. Etocynned Full Range 203 26th May 2012 03:36 AM
Optimal bass driver size for sound quality - is bigger really better? Antripodean Multi-Way 103 12th May 2012 10:55 PM
Assessing the quality of an SMPS commoncollector Power Supplies 4 24th January 2010 01:07 AM
Copyright 1999-2017 diyAudio
