Hypex - fiberoptic cable for panel light - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 16th November 2013, 12:43 PM   #1
Lightbulb Hypex - fiberoptic cable for panel light
Hi All, maybe this is interesting for hypex amp builders or any other amps with little LED's on them.
To get the light from these little LED's on the amp to the front panel, I took a cheap Toslink cable apart and routed it to the front panel of the amp. The other side went over the little led. The little gold ring around the light gives the whole thing a nice finished look. The light is quite discreet. Advantage is that it is passive and won't pick up any EMI.
The amp shown is a prototype but you get the idea
Best
Old 16th November 2013, 11:15 PM   #2
this is an alternative way to do it. Using the outer shielding of the cable...
Old 17th November 2013, 01:37 PM   #3
doctordata's Avatar
Default 1 mm LED's look very cool
Totally agree about the looks r100
Did the same thing , but drilled 1 mm holes in the front of my amp and only fed the fibers in the front panel . Looks great , Pictures don't show it that well , but high bright 1mm LED's look very good on your amp !
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Old 17th November 2013, 02:07 PM   #4
Cheers ,
Rens
Very nice ! and the light is free
40 Volt panel light replacement seebert Parts 4 17th November 2011 12:26 AM
Rotel RX-500 panel light? davestra Power Supplies 1 1st April 2011 11:13 AM
Would like to try and build a Tube pre/Hypex UcD 400 power unit for Light weight bass rim basses Class D 9 25th February 2009 11:34 AM
Copyright 1999-2017 diyAudio
