No Sound from Hypex UcD180 / SMPS400 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 15th November 2013, 01:27 PM   #1
Unhappy No Sound from Hypex UcD180 / SMPS400
Hi all,
I've put together a build with two UcD180HG amps and one SMPS400. I connected everything as in the diagrams found on this forum but I guess I have messed-up somewhere because there is hardly any sound from the amp. Turning the volume up on the pre-amp doesn't seem to make any difference. I have checked soldering, etc., re-checked the diagram but still no success.
The amps are wired with RCA plugs.
Diagrams used for wiring in post no. 6
Hypex SMPS400 + 2x UCD180 wiring (DC error, Auto Amplifier Enable, Amplifier Standby)
Any help greatly appreciated
thank's
Old 15th November 2013, 03:15 PM   #2
Update: I've re-wired pin 4 (J4) to the GND. Sound is a little louder but still very muted.
HELP ;-)
thanks
Old 15th November 2013, 08:31 PM   #3
Default Cookie box amp
I have rechecked all connection. The amp is wired the same as the first picture. On the second you can see the actual amp. Sorry, it looks like a birds nest but the connections are good.
Old 15th November 2013, 08:53 PM   #4
Davey is offline Davey  United States
I'm unclear why you've wired UcD pin 4 to ground. Both of those should go to the yellow wire on your SMPS and nowhere else.
The blue lights on the modules are turning on? You've checked for +/- DC power from the PS module?
Since you're using unbalanced inputs you should be on Pins 1&2.....Pin 3 should be open.
Dave.
Old 15th November 2013, 09:06 PM   #5
Smile Success, it finally is working !
Dave.
Thank's for that. Pin 4 (UcD) is back on the yellow wire on the PS. That was the initial setup I had. Not sure what you mean by Pin 3 open ? I have the shielded cable from Hypex which has a shielding and two cables in the middle. One of them is on the + of the RCA and the other together with the shielding on the chassis. I think this is what Hypex recommends.
In the meantime ....
In a last resort attempt I took the whole box upstairs where my main stereo is and hooked it up.. guess what.. it works !
I still have to figure out what was causing the problem, but I suspect that it was either a faulty pair of (old) loudspeakers I was using for the test or the LS cables...
Best to all.
R
PS will post some pics of the build when I get the enclosure.
Hypex SMPS400 + 2x UCD180 wiring (DC error, Auto Amplifier Enable, Amplifier Standby) maxw Class D 37 Yesterday 04:25 PM
Problem with Hypex SMPS400/67 (OEM V4) tatus Power Supplies 16 25th April 2017 02:42 PM
FS: 2x Hypex SMPS400 67V V4 cowanrg Swap Meet 2 16th September 2013 09:47 PM
Hypex SMPS400 Remote Control??? madtrapper Class D 0 27th August 2012 02:41 AM
Preamp for Hypex UCD180 dtaylo3 Class D 1 17th January 2012 03:26 AM
Copyright 1999-2017 diyAudio
