Hypex ucD180 balanced to unbalanced - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 13th November 2013, 10:58 PM   #1
Smile Hypex ucD180 balanced to unbalanced
caveat: total newbe
Hi all, I have ordered a kit to build a hypex amplifier (2 ucd180HG modules, 1 PSU). I would like to build it as recommended, i.e. as a balanced version. Source is a Pioneer N-50 and in between is a passive pre-amp to control the volume.
My question is: can I use a simple XLR to RCA adapter to interface the amp and the attenuator ? like this one?
Thank's all. Will be posting build pics once I've started and probably have some more questions.
Old 13th November 2013, 11:28 PM   #2
fpitas is offline fpitas  United States
Your link 404s. In any event, here's Hypex's wiring suggestion:
http://www.hypex.nl/docs/appnotes/wiring.pdf
Note the connection (both the shield and twisted pair) is continued balanced all the way to the RCA end. This uses the - (inverting) input of the UcD as a remote ground sense, which minimizes ground related issues.
Francis
Old 13th November 2013, 11:40 PM   #3
sorry about the 404.. fixed it .. the wiring of the adapter is as follows... is that ok ? thanks
3 pole XLR female – RCA / phono socket
Wired according to IEC 268-12:
Pin 2: signal
Pin 1 and 3: connected to ground
Old 14th November 2013, 12:51 AM   #4
That could be a good solution, as long as the adapter is located at the source, and you run an XLR cable to the UcD. I'd think you'd want a male RCA on the adapter in that case, like this one:
Francis
Old 14th November 2013, 02:30 PM   #5
Originally Posted by fpitas View Post
That could be a good solution, as long as the adapter is located at the source, and you run an XLR cable to the UcD. I'd think you'd want a male RCA on the adapter in that case, like this one...
Ok, got it. Only problem with that in my configuration is that it would make the passive pre-amp tilt over :roll eyes:
So, I was wondering if a simple RCA (source) to XLR (amp) cable would do ? Or should I just wired the amp unbalanced ?
thank's
PS. Just got the package from Hypex.. I wasn't expecting it so fast
Question about hypex balanced vs unbalanced Ace95982 Analog Line Level 7 25th May 2013 06:20 PM
Preamp for Hypex UCD180 dtaylo3 Class D 1 17th January 2012 04:26 AM
what preamp for hypex UcD180? DIY or used? zhai Class D 25 14th March 2008 10:40 PM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 07:54 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 07:18 AM
Copyright 1999-2017 diyAudio
