Hypex in Counterpoint chassis
Old 24th September 2013, 02:29 PM   #1
fwt1712 is offline fwt1712  Australia
Default Hypex in Counterpoint chassis
I have a pair of Counterpoint SA12s that are both working perfectly well but I understand the output devices are no longer available and if anything goes wrong with them I would have to look elsewhere.
So my question is - could I retrofit hypex modules and if so which ones. A peek inside at the circuit boards which says that the rails are +/- 40v (I haven't measured this, but assume it is right for the time being). From the hypex site this suggests ucd 180 modules. Assuming the ucd 180 will work with this rail voltage can I assume that I could connect the hypex into the power supply of the counterpoint, mate up the hypex heat sinks to the existing heat sinks of the counterpoint and connect the input and output connectors and have a nice new (nice sounding, cooler running and hopefully long-lived) amp using my existing case, transformer etc.
The one issue I can think of is do I need to organise any sort of soft start on the Counterpoint's power supply. The amp currently takes quite a while to start which I assume is a timer module or the warming up of the valve stages. From what I can see the power connects straight into the transformer and that there is no soft start or similar on this side of the amp. If anyone is familiar with the sa12 or has done a similar conversion I would be very pleased to hear from you.
regards,
Nigel.
Old 25th September 2013, 07:10 AM   #2
Minion is offline Minion  Canada
I believe that your amp uses IRF130 Hexfets which I believe are still available , at least a google search shows a lot of places with them in stock .....
As for the hypex I don't see why it wouldn't work ...
Old 28th September 2013, 05:28 PM   #3
tvrgeek is offline tvrgeek  United States
I changed over my Hitachi's in a Hafler to Exicons. A little work as the entire compensation plan had to change, but was very happy with the results.
Old 1st October 2013, 09:40 PM   #4
Greg Stewart is offline Greg Stewart  United States
Minion,
The SA-12 and SA-100 have both N-channel and P-channel MOSFETS, not just the N-channel ones. As I remember, they used fairly rare ones which ARE not manufactured anymore and hard to get. But...
Tvrgeek, can you provide more details on what you did to install the Exicons. Many of us with dead SA-12's and SA-100's would love to have that information!!!!
Greg in Mississippi
Everything matters!
Hypex in Counterpoint chassisHide this!Advertise here!
My new Hypex NC400 chassis Seungyun Lee Class D 30 21st December 2015 10:20 PM
Counterpoint Electronics/Counterpoint Acoustics/Counterpoint Audio tiefbassuebertr The Lounge 4 25th November 2014 02:06 AM
Hypex in Counterpoint chassis fwt1712 Class D 2 29th October 2013 03:27 AM
My Hypex NC400 chassis Seungyun Lee Class D 0 16th July 2012 12:22 AM
Recommend a project to fit in a Counterpoint SA100 chassis jrdmedford Pass Labs 3 12th September 2010 06:00 AM
