IRS2092S - ringing at gate drive pins
Old 19th September 2013, 08:12 PM   #11
knutselsmurf is offline knutselsmurf
you're probably fooled by your oscilloscope. If the rising and falling edge are the same I think this is the problem.
But to be sure. increase you gate resistor. you have to see a change. (22R is already a significant value)
hope this helps.
Old 20th September 2013, 02:34 AM   #12
DUG is offline DUG  Canada
Lower or raise the gate resistors by a factor of 2 and see if there is a change.
Just noticed post # 11
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Last edited by DUG; 20th September 2013 at 02:35 AM. Reason: Just noticed post # 11
Old 20th September 2013, 06:58 AM   #13
ionutzxpo is offline ionutzxpo  Romania
Send a message via Yahoo to ionutzxpo
Hy Shahin,in my IRS2092 amps, I use heavy snubering 680pF...1nF+27R/2W and I get allmost perfect PWM between the fets.I also use many 1uF/100V X7R across +->GND right next to fets (IRFB5615/IRFB5620) and GND-> - and right at the fets legs to GND SWF 400Khz .Great Sound
Iacob Ionut
Old 21st September 2013, 07:55 AM   #14
For a halve bridge, snubbering shouldn't be needed. Control you're FET rise and fall time with the gate resistor network. Slow on, fast off this will solve the problem.
Play around with LTspice.
For the good order this is a different problem.
ringing on the gate is mainly caused by Cgs.
and ringing on the leg of the halve bridge is caused by Cds and the inductor.
In a bridge configuration lowing the V/dt solve both problems. except if the Cds is really large. Then use a small snubber. But better find better mosfets. trade Rdson, for a lower Cds.
IRS2092S - ringing at gate drive pinsHide this!Advertise here!
Ringing on gate signal brandes.cm Car Audio 22 2nd January 2013 11:23 AM
Gate drive transformer...no v.us value eem2am Power Supplies 2 13th December 2011 02:09 PM
Transisor for drive gate mosfets theerasak khan Class D 0 6th September 2009 12:30 AM
Gate Drive Transformer microsim444 Everything Else 1 2nd December 2008 01:52 PM
Gate drive transformers? Loial Power Supplies 3 18th October 2005 10:17 AM
