TPA3116 amplifier power - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 15th August 2013, 10:45 PM   #1
Default TPA3116 amplifier power
I am interested by the following amplifier : TPA3116 Amplifier Board( 50W+50W ) D Class Amplifier Board-in Amplifier from Consumer Electronics on Aliexpress.com
Would it be possible to power it with 12V ?
Thanks a lot !
Old 15th August 2013, 10:58 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
It states that it requires at least 18volts. Sorry
Parameters
- Way of working: D class Static electricity: 50 ma
- Work efficiency: 90%
- The rated output power: 2 * 50 w
- Frequency response: 20 hz to 20 KHZ
- Operating voltage: DC18V to DC24V
- The maximum output current: 2 A
- PCB unit size: 81 * 69 mm
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 15th August 2013, 11:06 PM   #3
dfy is offline dfy
The TPA3116 chip actually works with voltages down to 5V. This particular board may or may not, but for a price as low as that I would definitely try it.
Take into account though that even if it works, you will get nowhere near the 50W+50W power claimed on a 12V supply.
Old 15th August 2013, 11:57 PM   #4
xrk971 is offline xrk971  United States
xrk971's Avatar
It will work with 12 volts just fine. Max power will be less than rated power. You should check out this thread TPA3116D2 Amp
Old 15th August 2013, 11:59 PM   #5
Thanks for the answers.
Indeed, the parameters say that it needs 18V at least, but very often, the specification are not that right on Aliexpress.
I will definitely try it if nobody did it yet.
And I am aware that I won't get 50+50W with 12V, but I need less than that.
Thanks a lot !
Old 16th August 2013, 01:31 AM   #6
Yes, I was surprised when bench testing it how few volts it took to turn it on.
Old 16th August 2013, 06:34 AM   #7
xrk971's Avatar
Thanks a lot !
If you look at the parameters as specified by the manufacturer, only 4.5 volts is needed and max is 26 volts.
http://www.ti.com/lit/ds/symlink/tpa3118d2.pdf
Old 16th August 2013, 05:55 PM   #8
radiosmuck's Avatar
Thanks a lot !
http://www.ti.com/general/docs/lit/getliterature.tsp?baseLiteratureNumber=slyy013
Check out page 4
Old 16th August 2013, 06:07 PM   #9
Originally Posted by radiosmuck View Post
Very handy chart there.... Thanks for the link...
Old 27th October 2014, 11:56 AM   #10
Send a message via Yahoo to oxoxbyx
how many ampere minimum for supply this amp ?
alteration of the power supply from the power amplifier Harman Kardon HK870 at 220. alexkmp3 Power Supplies 4 11th December 2012 04:39 PM
An amplifier to take to University - A small low power integrated amplifier monty78pig Solid State 33 31st August 2012 06:00 AM
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
