DIY Good Class D amplifier - Page 33 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 2nd April 2014, 07:32 PM   #321
Default Post #275 LTSpice file
Ok, here is the Spice file from schematic at post #275.
Look at current spikes thru diodes D2 and D3 (D4 and D5 in Acca's posted schematic)
Are those diodes going to fail?
Old 2nd April 2014, 07:59 PM   #322
Here is a screenshot of the high current thru diodes (output unclipped, 40v P-P)
Surprisingly, there is very little cross- conduction on the output MOSFETS though
Old 5th April 2014, 06:30 PM   #323
PetruV is offline PetruV  Romania
mine has just 3.5 a on diodes, which seems fine, since peaks are short
Just a kid who likes building and modding things.No inspirational quote here for you
Old 5th April 2014, 09:45 PM   #324
Will you post your spice file?
I removed D5 (the one that connects directly to the output) and that solved the problem, with no apparent problems from removing it. I don't think it was needed.
Old 7th April 2014, 08:45 AM   #325
The peaks look like simulation errors,they are very short and they look much different on different fets
Old 8th April 2014, 01:04 AM   #326
What is the purpose of the diode that connects to the output (D5)? I took it out and my circuit simulates better, and no more current spikes!
Old 15th June 2014, 07:48 AM   #327
Acca is offline Acca  Serbia
Acca's Avatar
Send a message via Skype™ to Acca
Few new (better) designs from me
All schematics is tested.(second schematic tried directly on 310V line,with IRF740)
Answer to Q about D5:
It's used to remove negative voltage on upper fet.
Old 15th June 2014, 07:53 AM   #328
Acca's Avatar
Yes,there is short current peaks because lower fet have small delay (in order to form dead time)
Old 15th June 2014, 07:54 AM   #329
Acca's Avatar
Originally Posted by Mondan View Post
I can say what I thought,
For a 'correct' dead time, you need need a digital circuit, as they did here with gates A1,A2 :
http://geekcircuits.com/wp-content/u...power-amp1.png
Because the signal is too weak, after these gates, you need a MOSFET driver (IR2010).
The price of IR2010 plus the remaining components It's almost as the price of IRS2092.(SMD version of IRS is cheaper). (Using this IRS, your risk of error is less)
I already ordered the IRS.
Still looking for very cheap variant class D amplifier (price of TL494 is less than SG3525)
For "correct" dead time we can use RD network too.
Before I try,I think same as you.
Old 15th June 2014, 07:59 AM   #330
Acca's Avatar
Originally Posted by MrPerform View Post
-And irfz48 it will serve?
-I will use it for listen some music at home not hi-fi.
-Is this possible with a smps at 56Vcc made from a ATX power supply conversion?
-Thank you and have a good weekend.
-Yes
-You are my man
-Why not?
-You too
A good 12v power supply to run small class D amplifier indoors? chipper Power Supplies 2 16th June 2014 03:57 PM
DIY Class-A audio amplifier APLY123 Solid State 0 13th July 2007 11:36 PM
A good Brazilian Amplifier, class A switching to AB in hi power destroyer X Solid State 65 24th March 2005 08:12 PM
Really good DIY Amplifier Info here! Zero Cool Solid State 2 15th October 2004 12:45 AM
Class A diy power amplifier jmar Solid State 1 18th January 2004 06:10 PM
Copyright 1999-2017 diyAudio
