IRS2092 own design
IRS2092 own design
Old 13th July 2013, 03:10 PM   #1
elektryk is offline elektryk
elektryk's Avatar
Default IRS2092 own design
Hi.
Can anybody tell me whether it will work?
Old 13th July 2013, 03:56 PM   #2
odnaizutra is offline odnaizutra  Guyana
hi,
this is a basic way to use ir2092.
No need to use high side external zener.
Double side pcb , using the other side as shielding would improve your Project and some smd 0.1 ceramic at switches from +B to _B as well.
Old 13th July 2013, 06:42 PM   #3
elektryk's Avatar
Good idea but high frequency device can work properly on this PCB? Routes are as short as possible, but I'm only hobbyist...
This inductor will be ok? DTMSS-16/0.022/8.0-V FERYSTER - Inductor: wire | Transfer Multisort Elektronik
Old 13th July 2013, 11:32 PM   #4
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I cant see much decoupling.
The 2092 and the mosfets need decoupling closely.
The layout needs to be as tight as possible.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 14th July 2013, 07:30 AM   #5
elektryk's Avatar
2092 and mosfets need to be closer? (On IRAUDAMP7D they are a bit further.)
Old 14th July 2013, 10:18 AM   #6
elektryk's Avatar
New version. (Mistake on R23 route.)
Old 17th July 2013, 03:54 PM   #7
Better now , but could be better if you move the coil and out cap to the place of electrolitics decouplers and place them nearer the MOSFETS.Try to make vs conection thicker .Keep in mind you have to place 0.1uF as close the MOSFETS you can.Place all the circuitry from pin 1 to 6 nearer 2092 to avoid pick emi .
Old 15th October 2013, 03:39 PM   #8
elektryk's Avatar
The most of parts arrived, if everything is ok, I will put it all together on this board and turn on...
Old 15th October 2013, 08:36 PM   #9
elektryk's Avatar
Soldering started.
Old 16th October 2013, 05:46 PM   #10
elektryk's Avatar
How compute resistors for OC protection with IRF640N?
IRS2092 own designHide this!Advertise here!
My design L20D IRS2092+IRFI4020H 200W8R ljm_ljm Class D 1081 28th June 2018 11:48 AM
IRS2092 Through hole working design jash2008 Class D 16 31st December 2011 12:05 AM
IRS2092 Amp Design: Please help! Devendra Class D 11 17th March 2011 09:10 AM
IRS2092 Amp Design Review brent113 Class D 22 17th June 2010 05:30 PM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
