Interaction class D amplifier and speaker
Old 4th July 2013, 09:39 AM   #1
Domid31 is offline Domid31  France
Default Interaction class D amplifier and speaker
Hello,
I intend to build an active speaker, with integrated class D amplifier (350 W bridge, based on IRS2092 chip).
As the amplifier will be close to the speaker, do I have to protect it against magnetic field generated by the speaker ?
Thanks for expertise !
Old 4th July 2013, 10:08 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Magnetic field is not an issue however vibration is!
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 4th July 2013, 11:20 AM   #3
Tekko is offline Tekko
Banned
You might want to put some selastic on the larger components to keep them from vibrating loose over time.
Old 4th July 2013, 03:02 PM   #4
phase_accurate is offline phase_accurate
Good active speakers have an acoustically insulaed compartment for the electronics anyway. But this comes at the cost of increased overall volume.
Old 4th July 2013, 04:20 PM   #5
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
In theory, the magnetic field of the speaker could push the inductors in your amp/power supply closer to saturation.
Provided you keep everything a few inches apart at least, you should be fine.
Old 8th July 2013, 08:07 PM   #6
Thanks for your answers.
I already considered vibrations, the amp will be mounted using 'silent blocs' (I do not know if this is good english).
Interaction class D amplifier and speakerHide this!Advertise here!
Class D VS. Class T, Help setup with passive speaker sabio0 Class D 1 29th November 2012 04:37 PM
Sinewave 50W+200W CLASS D ACTIVE SPEAKER AMPLIFIER MODULE boudy Class D 5 15th January 2011 04:28 PM
How to model speaker interaction in common chamber dih1118 Multi-Way 0 22nd September 2003 02:25 AM
