Class D module needed - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 11th June 2013, 03:26 PM   #11
Banned
This sounds like its a PA amp judging from the rail voltages. Depending on what transistors were used, repairing it might be more than getting a new amp.
Did it just decide one day that it dident wanna live anymore and committed suicide or did it happen by accident such as a unintentional short of the speaker outputs while at moderate output power ?
Old 11th June 2013, 04:09 PM   #12
"Did it just decide one day that it dident wanna live anymore and committed suicide or did it happen by accident such as a unintentional short of the speaker outputs while at moderate output power ? "
It was during some tests with no speakers connected that my DSP put out garbage at full level +20dBu that killed the amp.
Don't think the transistors are that expensive - guess that 8 or 10 of the are short. 2SC5359 / 2SA1987
Old 11th June 2013, 04:43 PM   #13
Banned
A good design should survive a full +20dBu signal with no load no problem as it is essentially the same thing as turning your hifi to full volume with no speaker connected, never seen a home amp fail from that. I have even done it into loads well below the manual "absolute minimum load" witn no problems.
I would guess your amp was already on death row before this, ie already failing(like a bias circuit starting to go bad causing thermal runaway) where the full volume input was all needed to send it over the edge.
Old 11th June 2013, 05:36 PM   #14
...should survive.... but for an 14 Years old amp there is no guarantee...
Old 11th June 2013, 05:40 PM   #15
Banned
Yeah like i said, was probably already at its left leg and that input was enough to send it over the edge.
It could possibly also be one of those designs that without load jumps into uncontrolled oscillations beyond a certain output level causing instant destructive failure.
Old 27th August 2013, 11:40 AM   #16
The issue is "solved". I ve scrapped the old amp (anybody here needs TO247 complementary Power Bipolars for cheap? Or a big 50Hz toroid?), bought and installed a Class H Camco D Power 2. System is running again.
Old 28th August 2013, 01:31 AM   #17
nigelwright7557's Avatar
The nearest IC I could find is the irs2092 which can cope with 220 volts max.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 28th August 2013, 01:48 AM   #18
theAnonymous1's Avatar
I didn't see it mentioned here, but you would have some serious bus pumping issues running half-bridge at those power levels anyway.
Old 1st September 2013, 08:08 PM   #19
NMOS is offline NMOS  Germany
NMOS's Avatar
+/-120 V DC Class D Modules are available
digitclass.net
TN5000 SPECIFICATIONS:
850 W @ 8 ohms (+/-125V)
1,450 W @ 4 ohms (+/-125V)
2,550 W @ 2 ohms (+/-125V)
1,070 W @ 8 ohms (+/-140V)
2,030 W @ 4 ohms (+/-140V)
2,700 W @ 2.66 ohms (+/-140V) (ไม่แนะนำกรณีใช้งานจริง)
Input Impedance : 47k ohms unbalanced
Frequency Response : 20 Hz - 20 kHz
Supply Voltage : +/-75V to +/-140V
Bias : Include
ราคาเต็ม: 2,150 บาท
พิเศษ ราคาโปรโมชั่นช่วงแนะนำสินค้า 1,750 บาท
Old 1st September 2013, 10:02 PM   #20
The website is slow with strange letters and I couldn't find any datasheet. But still - an option to get my Sony amp working again.
Which class-D module you think the best iceman009 Class D 2 26th May 2013 08:08 PM
class D amplifier module,power amplifier module sunlight009 Vendor's Bazaar 2 19th October 2011 02:02 AM
D Class Module for 3 way DQ828 Class D 19 23rd December 2010 11:51 AM
SMPS for class D module NewTesla Class D 40 16th May 2010 08:38 PM
Copyright 1999-2017 diyAudio
