Need a UK Power Supply Recommendation for a T-Class Amp - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 10th June 2013, 03:33 PM   #1
nickb23 is offline nickb23  United Kingdom
Default Need a UK Power Supply Recommendation for a T-Class Amp
Hi guys,
Just bought one of these SMSL Amps - SMSL SA-36A 2*20W TA2020 Tripath Class T Amp Stereo Amplifier Gold | eBay
and I need some advice on a UK power supply. I believe I need a 12v 3amp to get the most out of it, but at the mo I have a 12v 1.5amp, which works. With more amps I believe I should be getting more power and bass - is that right??
These are working with my iPhone, along with a pair of Celestion F1 Bookshelf speakers.
Also any recommendations on a good cheap bargain phono to 3.5mm cable too ;-)
Nick
Old 10th June 2013, 04:13 PM   #2
Banned
The psu these SMSL amps sometimes come with i believe is in the 4-5A range.
Old 10th June 2013, 05:54 PM   #3
Thanks for the reply, Tekko. I have found this one.....
DC 12V 3.8A Power Adapter Supply Switch Converter Charger for Security Camera/T- | eBay
But this is a shipment from China, so I am looking for uk based alternatives. I have found this one on amazon.....
http://www.amazon.co.uk/Monitors-Hun...t+power+supply
This one is 12volt / 5a - could it still be used with the SMSL amp??
Does more amps make it bassier and louder???
Thanks guys
Nick
Old 10th June 2013, 06:27 PM   #4
Banned
That will work a treat as long as the connector fits.
Old 10th June 2013, 06:29 PM   #5
seems too.. 2.5mm inner 5.5mm outer. Would having a more powerful psu make a difference to the sound quality?? I have also read about people buying expensive psu with clean electricity etc. Does it make a difference???
Old 10th June 2013, 06:46 PM   #6
Banned
Well with more Amps, the amp will be able to reach its full potential, a dirty psu really only affect noise floor.
Old 10th June 2013, 07:27 PM   #7
brig001 is offline brig001  United Kingdom
Bassier? No. Louder? Yes.
Try CPC. A quick search brought this up on my phone (click "full site" on a PC)
POWERPAX - PTD-1205A - AC ADAPTOR, 12V, 5A REGULATED 2 PIN; - CPC
Hope that helps,
Brian
Edit: they sell the cable you want too
Old 10th June 2013, 08:12 PM   #8
ATAUDIO is offline ATAUDIO  Austria
Yes, 1.5 A is a little too small. However, mind hat with an Apple stuff, you probably won´t get a lot of power out of the SMSL because of the limited input signal you are giving to it, so , thanks to the big filter capacitor you have inside the box, it might do anyway.
At the moment, the only phone/player/reader/toy that could put it "with its shoulders against the wall" is the little Sansa Clip + modified with the Rockbox firmware. About 1.8 Vpp , 1kHz, 0 dB reference signal. And you can go up to +6 dB....
@Audio
Old 11th June 2013, 10:13 AM   #9
as long as you stick with 12v the ampage can be any because the t-amp will only draw what max amp it can
Old 11th June 2013, 04:36 PM   #10
Are you sure? Just measured 3V pk-pk on the line out and 2.8V pk-pk on the headphone socket on my 4s.
Brian
Class D amp Regulated power supply?? DionG Power Supplies 5 31st July 2011 04:12 AM
Need recommendation for power supply for TA2020 maurycy Chip Amps 0 25th November 2008 03:05 PM
power supply recommendation for EL84 amp chevelle Tubes / Valves 5 16th January 2006 12:41 AM
UK Power Supply for T Amp joesan Class D 9 24th November 2005 12:26 PM
S5 Amp kit Power supply for UK Centural Tubes / Valves 12 3rd January 2003 01:42 PM
Copyright ©1999-2017 diyAudio
