TPA3116D2 Amp
TPA3116D2 Amp
Old 18th August 2014, 01:33 AM   #4431
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
TPA3116D2 Amp
Someone could try a buffer in front (DC coupled B1?) and higher gain.
Old 18th August 2014, 02:25 AM   #4432
matt_garman is offline matt_garman  United States
TPA3116D2 Amp
Here was my weekend project: putting together a little amp using the new Sure tpa3110 board. The original Sure tpa3110 board got me started down this rabbit hole of intrigue and obsession.
Nothing special about this build, just thought some might enjoy the pics. The board is stock (except for the screw terminal blocks I added). I intend to replace the stock electrolytic caps with the OSCONs (soon as they are delivered).
Have only done a minimal amount of listening so far, but I really like what I hear. I always liked the original Sure 3110 board. Might just be a case of "new gear syndrome", but right now I'd have to give this one the nod over my modded YJBlue 3116. Can't really put my finger on it, but the best analogy would be that this amp has the "blacker blacks" if we were talking plasma TVs. My only complaint with this board is that there is a power-off pop. To address that, I'm going low-tech and will just add a little rocker switch to connect the "SD" and "GND" pins. Using a paper clip right now, while I wait for additional screw terminals and a switch to be delivered.
Old 18th August 2014, 03:10 AM   #4433
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
TPA3116D2 Amp
Matt_Garman,
Looks really nice there. Where do you get your cases?
Blacker blacks huh? Intriguing...
Old 18th August 2014, 04:14 AM   #4434
KJA 2013 is offline KJA 2013  United States
Attachment 433691
Attachment 433692
I really like these two new boards from Sure, especially the 3116. Here's what I did with mine. With only a set of Oscons a good home made power supply, quality wire and hardware, this board has fast become my favorite by a good margine. These dark boards with dark solder mask make it hard to see exactly how everything is being implemented... maybe it's just a better match with my speakers....whatever it is, I like it a lot.
File Type: jpg Sure TPA3116 - KJA - Oliveros Cherry Amp .jpg (564.8 KB, 571 views)
Old 18th August 2014, 04:46 AM   #4435
Got Foam?
xrk971's Avatar
TPA3116D2 Amp
I think we have a new Weiner here with the Sure TPA3116D2 (silkscreen error notwithstanding)? $25 is a great price for having nothing more than a pair of OSCON's to swap out.
Nice box there KJA 2013! I like the red look and it is not rectangular but curved sides.
Old 18th August 2014, 05:26 AM   #4436
jencelo is offline jencelo  United States
SURE's reply for the polarity and connector issues.
"Thanks for your letter.
I have checked the polarity with our technician and they are indeed opposite.
We feel so sorry for the inconvenience and we will modify this error in our next production.
Regards the size of power connector is 2.5mm*5.5mm. So the 2.1mm*5.5mm connector can not fit into it."
Sent from my iPhone using Tapatalk
Old 18th August 2014, 05:57 AM   #4437
TPA3116D2 Amp
So you think the bootstraps, inputs, and inductors are really that good?
Old 18th August 2014, 06:28 AM   #4438
Thanks! The new board fit perfectly into the little red box. I have a second sample of the Sure 3116 to try this week. I'm hoping it's just as good.
Old 18th August 2014, 09:56 AM   #4439
risperdal is offline risperdal  Germany
Default SMSL SA-36A Pro TPA3118 amp
Anyone tried other caps( 8x 470uF/25V Panasonic M electrolytic caps) in this place (FC/FM or polymer)?
Old 18th August 2014, 12:35 PM   #4440
rhing is offline rhing  United States
rhing's Avatar
In my SMSL SA-36A Pro TPA3118 amp, I first replaced the 2x 47uF/25V DC decoupling caps (not sure if these are OSCON-type or hybrid-type) with 2x 330uF/25V Panasonic SEPF OSCON caps. This made a significant improvement in sound quality in terms of articulate bass, cleaner treble and warmer midrange. The sound stage became bigger too. After several weeks, I replaced the 8x 470uF/25V Panasonic FM electrolytic caps with 8x 470uF/25V Panasonic M electrolytic caps. My preference would have been to use 4x or 6x 680uF/25V Panasonic FM caps as these have a lower ESR than the 470uF/25V Panasonic FM caps, but they were too tall to comfortably install in such a compact enclosure.
Never the less, the upgrade made a subtle improvement with dynamic transient response and extended bass. Also, the very slight background hiss I heard before with my ear next to the tweeter was further diminished. Overall, I am quite pleased with the parts upgrades, and I've been using this amp as an integrated amp on very warm weather days when I don't want to use my tube amps.
Rich
TPA3116D2 AmpHide this!Advertise here!
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 02:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
