Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Class D Switching Power Amplifiers and Power D/A conversion |
#341 |
They are used in the amp10 from 41hz. The only drawback is that they're through-hole which makes it a little annoying when designing an amp meant for having components only on one side and the reverse full ground plane thermal glued to a heatsink.
#342 | |
#343 | |
You can also run TPA3116 with ferrite bead output filter only but it's highly recommendable to use a full LC output filter due to the increased efficiency and sound quality you achieve with a properly designed LC output filter. You should under no circumstances run a TPA3116 completely filterless! |
#344 | |
It the fact its an LC, not LR or LC which bothers me. Flat impedance is actually quite important with these amps id guess. Its a downside,not necessarily a dealbreaker
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess. Last edited by mondogenerator; 21st September 2013 at 07:52 AM. |
#345 |
#346 |
#347 |
Is there a "real" sonic advantage to be had replacing the coils because the board now looks pretty ugly?
#348 |
#349 |
#350 |
Thread | Thread Starter | Forum | Replies | Last Post |
FS- Twisted Pear Buffalo 32S Board & System New & Unused | secretriches | Swap Meet | 1 | 10th August 2009 02:17 PM |
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 | quality sound | Tubes / Valves | 0 | 9th May 2009 03:59 PM |
Krell KSA 80 bias & dc offset check & adjust procedure | Clouseaupte | Solid State | 3 | 9th August 2007 09:39 AM |
DIY-AMP <ZAS> Low THD & IM high bandwith | murphy | Solid State | 18 | 30th December 2005 10:28 AM |
New To Site? | Need Help? |
