Go Back   Home > Forums > Amplifiers > Class D
Old 14th February 2014, 11:54 AM   #1741
Originally Posted by hajj View Post
Or you could use a blue LED and make Jean-Paul go nuts
Originally Posted by jean-paul View Post
NEIN, not blue !
Old 14th February 2014, 02:01 PM   #1742
Qbert25 is offline Qbert25  Italy
Green is ok, but 8k2 resistor seems to be too high.
I=(19-2)/8200=2mA
I think "I" should be around 15-20 mA that means R=1000 ohm, isn't it?
Old 14th February 2014, 02:05 PM   #1743
diyAudio Moderator Emeritus
jean-paul's Avatar
2 mA is enough for a very soft glowing standard green 3 mm LED. Or it must be that you like to wear sunglasses while listening.
6k8 is OK for a normal glowing standard green 3 mm LED. Older generation LEDs needed 10 to 20 mA. Please try out what you like. IMO the equipment itself should not distract from listening but you might think otherwise and that's OK.
It's only audio. Official member of the Norske Brillegeit Gang.
Old 14th February 2014, 02:17 PM   #1744
Saturnus's Avatar
Using a power LED that requires 15-20mA seems extraordinarily excessive as it would double the idle power consumption of the amp.
Old 14th February 2014, 02:24 PM   #1745
skrstic is offline skrstic  Serbia
If it's green it's OK.
Old 14th February 2014, 04:11 PM   #1746
In that light (ha ha ) given that these are extraordinarily efficient amps, what would be the most efficient way of making an 'on' light/led ?
Old 14th February 2014, 05:03 PM   #1747
Ok, here are my tests:
- green led with a 5k resistor works well!
- 100F capacitor doesn't work.... bumps still there
Old 14th February 2014, 05:27 PM   #1748
Saturnus's Avatar
Not to have one at all. Don't really see the point of it but you are welcome to explain why you'd want one.
Old 14th February 2014, 05:51 PM   #1749
rsavas is offline rsavas  Canada
LEDs
Hint: Use a constant current source set at a low value such as 2-5mA or what ever brightness you like. Use the SDZ control to disable the CCS so that idle I is only that of the 3116.
The CCS allows for constant LED brightness regardless of the supply V.
... even we designing our boards we cant compete with that
Sure you can but you have the mfg over there where people work for a bag of rice and you have to buy the comps in bulk. It is a numbers game.
I worked for a lighting ballast mfg recently, where Philips was our biggest customer. We could sell ballasts to them cheaper than they could make their own,Advance brand. We are talking shipping containers of them. Why, cheap mfg and comps, where every penny counted. With this method came some real reliability headaches. I know I heard the complains from irate customers.
Back to the hockey game.
Cheers
Rick
Old 14th February 2014, 08:23 PM   #1750
xrk971 is online now xrk971  United States
xrk971's Avatar
Does anyone know if the Feixiang 2.1 board with 4 trimpots have an adjustable sub woofer XO frequency?
2.1 TPA3116 Hifi Class D Digital Amplifier Board 100W + 50W + 50W 50mA 12V 25V-in Consumer Electronics on Aliexpress.com
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 02:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
