4CH 1200W ICEPOWER AMP/ I changed it
Old 10th May 2013, 09:45 AM   #1
yorkjoy is offline yorkjoy
Send a message via Yahoo to yorkjoy
Default 4CH 1200W ICEPOWER AMP/ I changed it
the original ICEPOWER1000A power is low, which is only 500w/8ohms.
I changed the circuit a little, added output transistors, and increase the voltage to 150V, so that the power now is 1200w/8ohms, 2400w/4ohms.
check out the pictures.
any comments is appreciated, thanks!
Old 10th May 2013, 10:05 AM   #2
Reactance is offline Reactance  South Africa
Reactance's Avatar
Interesting mod. what is the rail voltage now after the mod? and what was the before and after output transistors ?
I'm sure increasing the supply voltage wont cause side effects what is the before and after supply rails ?
There’s nothing worse than the smell of burned output transistors!!
Old 11th May 2013, 08:06 AM   #3
the voltage was 120V, and now is 150V.
the output transistor was FDB2532, and now is IRFB4427.
the drive was IR2010, and now is IR2110.
Old 11th May 2013, 08:22 AM   #4
hehe...when available will try to modify the circuit board and use T0247 Encapsulation IRFP4232 IXFK102N30P, 2000w/8ohms, and see whether the module can reach to 2000w/8ohms
Old 11th May 2013, 04:14 PM   #5
dudaindc is offline dudaindc  United States
dudaindc's Avatar
Interesting...
Do you have the original and modified schematics? If so, would you be willing to share?
Which power supply are you using? Is that from another commercial product?
Thanks!
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 16th May 2013, 01:18 AM   #6
Shaun is offline Shaun  South Africa
Shaun's Avatar
What is the operating frequency of this circuit?
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 16th May 2013, 03:15 AM   #7
paskal9 is offline paskal9  Malaysia
paskal9's Avatar
have you tested the amp at maximum output or near maximum output? drawing more than 1kw of power from any type of design is a mean feat, and not many are capable of doing so.
it's one thing to make the circuit stable at high rail voltage, but that doesn't necessarily mean that it'll be able to sustain high power output and still be stable while doing so.
Old 16th May 2013, 09:33 AM   #8
Reactance's Avatar
Your future attempt to increase the power supply further will render the device into flames, i don't think the original design will permit this, i do think its a bit over ambitious.
Hypex modules don't allow this form of modifications for a reason im looking at a datasheet for its Ncore modules and see its got UV, OV and OC protection schemes incorporated into the modules.
Old 16th May 2013, 02:24 PM   #9
Originally Posted by dudaindc View Post
Interesting...
Thanks!
we use the power supply simlilar to the Labgruppen FP series, just change double power supply to single power supply.
I plan to make it to a commercial product, now it's just a demo.
Old 16th May 2013, 02:25 PM   #10
330KHz
4CH 1200W ICEPOWER AMP/ I changed itHide this!Advertise here!
4ch signal splitting heaphone amp themadhatta Chip Amps 9 8th May 2013 04:14 PM
qsc amp 1200w Jonsen Solid State 16 28th January 2013 08:54 AM
Looking for inexpensive, non-diy 4ch amp for woofers pjanda1 Solid State 2 18th February 2011 06:52 AM
FS: 4 x LM4780 4ch Amp Built alexcd Swap Meet 7 19th November 2008 08:30 PM
Looking for a 1ohm 1200w ac amp for subwoofers Mendoza Subwoofers 6 27th November 2007 05:51 AM
