New Sure TDA7492 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 24th April 2013, 08:47 PM   #1
rikkio is offline rikkio  Netherlands
Default New Sure TDA7492
recently I ordered this amp sure to electronics.
2 X 50Watt Class D Audio Amplifier - TDA7492_Special Offer_Sure Electronics' Webstore
In the past I had a customized (reduced input resistance) TA2024 and TA2020 in my boombox.
Given the small price difference, I have now chosen an amplifier in a cabinet so that I can easily swap it different setups.
On my laptop its fine, but on my ipod the power is dissappointing.
Unfortunately, there is no schematic online. Mail to Sure Electronics not been answered (yet)
http://imageshack.us/photo/my-images/705/adsc06250med.jpg/
ImageShack® - Online Photo and Video Hosting
Anyone know if it is possible to reduce the input gain (reducing a resistor) to increase power?
advice is greatly appreciated.
Old 27th April 2013, 06:05 PM   #2
Default Schematics
The guys at Sure Electronics send me the schematics after some mail traffic.
With the TA2024 I had to lower the resistor in front of the line-in to the processor from 20k to about 6k.
I have looked for resistors in front the processer. C25 C26 seemed logicalI to me. have resistors c25 and c26 lowered from 10k to 5k but that did not work.
Still trying to figger it out.
here's the schedules they sent me,
Old 27th April 2013, 06:56 PM   #3
Mooly's Avatar
Its in the data sheet for the TDA7492
Old 27th April 2013, 08:01 PM   #4
I think that datasheet belongs to this amplifier
2 X 50Watt Class D Audio Amplifier Board - TDA7492_Class D Amplifier Board_Audio Amplifier and other Audio Boards_Audio_Sure Electronics' Webstore
discussed in this topic
Sure TDA7492 board - adding a standby and volume pot (bass amp)
i can't find any switches on my board
or
am I wrong?
thanks
Old 27th April 2013, 08:29 PM   #5
Or did you mean
"the gain is set by changing the feedback resistor of the amplifier" ?
I'll have to find de feedback resistor
Old 28th April 2013, 06:21 AM   #6
Mooly's Avatar
You have to measure the logic level on pins 30 and 31. It is possible that yours is already running at the maximum gain if both those pins are at 3.3 volts. If you need still more gain then you are going to have to add a simple gain stage (preamp) in front of the amp.
Old 28th April 2013, 06:37 AM   #7
Saturnus's Avatar
Originally Posted by rikkio View Post
Or did you mean
There is no external feedback resistor. The feedback resistor is set with the gain pins (pin 30 and 31) as mentioned above. It's in the chips data sheet.
Old 28th April 2013, 07:17 PM   #8
That did the trick!
Gain pin 30 en 31 where at 0 Volt.
VDDS at 3.3 Volt.
Gain pin 30 was connected to the Ground through 0 (!?) Ohm resistor (nr. R6).
I removed this resistor and shorted the Gain to VDDS throug (nr. R10) which was blank.
The amplifiers power increased a lot using the ipod.
Maybe even more of I do the same trick with pin 31 which is called Mode instead of Gain2 in de schematics.
Thanks Mooly and Saturnus
Old 19th February 2016, 05:21 PM   #9
Oil is offline Oil  United Kingdom
Default photos
Just to add a couple of photos of the fix for lowest gain / low volume problem on this board - see attachments.
25W TDA7492 and 50W TDA7492 ??? Wieslaw Lipowsk Class D 4 8th March 2017 08:06 AM
Active tube preamp with TDA7492 ? Wieslaw Lipowsk Class D 4 18th July 2013 05:57 AM
TDA7492 baggins Chip Amps 5 26th November 2012 10:08 PM
Class D + No load = Shorted tda7492? riotpack Class D 5 15th September 2012 10:09 PM
Need your opinon regarding TDA7492 based amp shaharg Class D 2 24th August 2012 01:45 PM
Copyright ©1999-2017 diyAudio
