Fixed "mistakes" on great sch :) - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 22nd April 2013, 02:57 PM   #1
Default Fixed "mistakes" on great sch :)
Somebody here posted sch for single supply stereo d class amp.I am new here and very long in this problematic so i saw instantly that he didnt post sch honestly but he cut 4 connections to make ti to not to work.However this is corrected sch.This Amp is really powerfull and high quality one.
Old 23rd April 2013, 10:17 PM   #2
nigelwright7557's Avatar
I cant see a feedback path so it will hum nicely at low input levels.
It will also have quite a bit of distortion at higher output levels as the output modulates the power supply.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 23rd April 2013, 11:15 PM   #3
JonSnell Electronic's Avatar
Class D doesn't have a feedback path, it is either on or off.
Old 23rd April 2013, 11:41 PM   #4
Quality class d amps have pre or post filter feedback.
Look up the class d irs2092 datasheet and you will see it uses pre filter feedback.
Old 23rd April 2013, 11:57 PM   #5
Reactance's Avatar
kind of like human logic either smart or very stupid. "either on or off"
There’s nothing worse than the smell of burned output transistors!!
Old 24th April 2013, 03:51 AM   #6
DUG is offline DUG  Canada
TPA3116...internal feedback (inside the IC)
http://www.ti.com/lit/ds/symlink/tpa3116d2.pdf
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 25th April 2013, 10:34 AM   #7
Guys , its nice to comment about D -class .... but AFTER u build and try something.I have behind me at least 10 differents concepts and all r working great......on each concept i made minimum 30 to 50 power amplifiers.So i will try explain a few things.The only hum and noise can exist on output on this schematic only if u put them on input.ON and OFF concept is right one and good starting point to think.....I can tell u that this is good design and very powerful,easy to make,try and play with.Point is that somebody posted this here and posted it with mistakes which r now corrected,so u r welcome .
Old 25th April 2013, 03:17 PM   #8
Ouroboros's Avatar
As your schematic shows no NFB path, any noise on the PSU lines will get straight to the speaker. If you added a proper frequency-compensated op-amp input stage with NFB taken from the switching side of your output inductor it'll make a reasonable amp.
I would be very wary of making foolish comments about "after you build something". There are quite a few of us here who are employed to design class-D amplifiers and know a great deal more about the subject than you will for a few years if you think the schematic you have posted is anything like the state of the art!
Old 25th April 2013, 03:24 PM   #9
godfrey is offline godfrey  South Africa
Where is that one? It would be good to show the correction in that thread too.
Old 25th April 2013, 05:57 PM   #10
Top page,red lines.Did u post that schematic?
"Ground Loop" in Snubberized PSU *fixed* Redshift187 Power Supplies 2 18th March 2012 01:34 AM
Rheostat for adjustable "fixed" bias? porkchop61 Tubes / Valves 11 25th April 2011 08:57 PM
Need a good recommendation on a "great" sounding 7.2 surround amp Thaedge Solid State 0 10th March 2011 03:49 PM
EL34 pp "fixed" bias is wandering OzMikeH Tubes / Valves 14 6th May 2008 02:17 PM
cheap 6" or 8" woofer to make great bass for a standard cab pick up zuki Subwoofers 12 15th February 2005 07:54 AM
Copyright ©1999-2017 diyAudio
