Predictive Energy Balancing amplifier
Old 29th March 2013, 12:46 AM   #1
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Default Predictive Energy Balancing amplifier
"Predictive Energy Balancing, (PEB), allows immediate, direct feedback in a switched-mode power converter by effectively removing the filter pole from the feedback loop. Predictive Energy Balancing makes switching decisions based on the eventual outcome of those decisions, which can be calculated in advance using the fundamental energy equations. In the process, the unavoidable delay of the output filter is removed from the feedback loop. PEB allows the maximization of both agility and stability."
New approaches to switched-mode audio power amplifiers (Part 2) | EDN (3 pages)
File Type: jpg new_approaches_switched_mode_amplifiers_fig5.jpg (190.9 KB, 118 views)
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 1st April 2013, 10:47 PM   #2
ChocoHolic is offline ChocoHolic  Germany
...not going to step in the discussion whether predicting energies in a power circuit is new or not...
But I would like to highlight that most common speakers do not at all act with high fidelity, when operated with energy drive instead of voltage drive.
Consequently this method would only make sense as an inner loop, with an additional outer regulation loop, which then provides voltage drive to the speaker.
Predictive Energy Balancing amplifierHide this!Advertise here!
Energy ES18XL subwoofer amplifier need schematics renehuot70 Solid State 0 20th April 2012 01:52 PM
Balancing Servo Jeb-D. Tubes / Valves 2 6th January 2010 04:15 AM
balancing speakers JohnST Multi-Way 3 19th July 2004 11:42 AM
Balancing Raka Analogue Source 6 18th April 2004 07:04 AM
Balancing a 3 way VictorG Multi-Way 5 29th October 2003 02:41 PM
