irs3000d
irs3000d
Old 30th April 2013, 05:07 PM   #11
Tekko is offline Tekko
Banned
They don't, the ratings are grossly overrated as well as beeing a oneshot few millisecond pulse into the absolute minimum allowed load impedance using a lab power supply rather than a real power supply.
Old 30th April 2013, 05:23 PM   #12
Reactance is offline Reactance  South Africa
Reactance's Avatar
isn't this refereed to burst testing .
There’s nothing worse than the smell of burned output transistors!!
Old 30th April 2013, 07:10 PM   #13
Banned
Yeah, and the burst tests are usually what manufacturers use as the power specs just to make their producs look better than they are.
Old 30th April 2013, 08:37 PM   #14
stewin is offline stewin  Kenya
hi nazir
i have made the ir900 and the ir4k5 both work but you have to be extra careful when soldering ,because the tracks are small.
i haven't tried the ir3000 but there are a lot of complains from diyers.
i would recommend you go with manoj,s aud600 it is powerfull and many diyers have build it including me
Old 4th August 2013, 09:15 PM   #15
b e h n a m is offline b e h n a m
hi
i have made IRS300 and it work nicely
i use 6k8 as Rss and test it with duble 60 & 75.
is 6k8 right resistance for this voltage ?
how can I know how much must use per diferent voltage ?
i can't find orginal mosfets then i use IRFP250
hef4049 Instead cd4049
Old 21st June 2016, 12:03 PM   #16
herimanana is offline herimanana  Madagascar
hi there,.
could please tel me what means OSC ? RFB ? OCP ? in the PCB layout of irs3000D ??
Old 31st December 2017, 05:20 PM   #17
radokely is offline radokely
oCp means overcurrent protection...rfb means resistor feedback it set the gain of the amp
irs3000dHide this!Advertise here!
