SMSL SA-S1 low volume noise - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 9th April 2013, 05:56 AM   #11
xrk971 is offline xrk971  United States
xrk971's Avatar
Try connecting the negative of the power supply, the negative of the RCA inputs, and chassis/casing to common EARTH ground (connected to ground on 3-pin wall power). I had a similar hiss that went away after I did this. I think the negative of the audio input is especially susceptible to noise pickup when not properly grounded if not being driven by true balanced input line drivers.
Old 4th June 2013, 03:18 PM   #12
sm2yer is offline sm2yer  Sweden
Connected my brand new S.M.S.L SA-S1 amplifier and discovered this problem, exactly as described Question: AnyOne tested the mod with changing C104 as 'ostrichmilkman' described? - Is this infact what's done to the 'factory replaced' unit you received as replacement for your faulty unit?
Old 4th June 2013, 11:29 PM   #13
Default Replaced C23 - Unit works fine!
Thanks to all, i modified my unit according to posted image from 'ostrichmilkman' with the original tantal capacitors value of 1nF (101T) in mind i tried to get a value as close, but still larger to get the wanted result (= no noise) I'm now @ 4,7nF (472) with good result. No noise and no noticeable negative change to the sound. Pictures @ http://195.84.101.101/~goranl/projects/nad_stereo/SMSL_amp/
Old 5th June 2013, 05:11 AM   #14
rhing is offline rhing  United States
rhing's Avatar
Glad you were able to fix the problem. My unit did not have a problem with the Tantalum cap, but with a channel imbalance at low volumes. Rather than request a replacement amp, I asked SMSL for a replacement volume pot, which they promptly sent to me. After installing the replacement pot, both channels are now balanced and the sound quality is quite impressive. I definitely prefer this over my modified Sonic Impact 5065 Gen 2 T-amp and the Arjen Helder TA2020 MkIII T-amp. It's smoother, equally dynamic and the soundstage is more three dimensional. I initially had my doubts about the ERO MKT1813 input caps, but after about 80 hours of playing time, the amp has really opened up and the bright treble has smoothed out, while the bass and midrange have become fuller and better defined.
Rich
Topping TP-20 Mk2 or SMSL SA-S1? kin0kin Class D 4 6th February 2012 04:39 PM
SMSL SA-36 funnies flyinglemur Chip Amps 1 7th January 2012 03:18 PM
Low distortion & noise digitally controlled volume chip abraxalito Analog Line Level 6 13th August 2011 02:14 AM
Which T-Amp? SMSL SA-S3 or Topping TP21? TylerDurden Class D 1 17th July 2011 03:42 PM
Help me regarding very low Supply Ripple output noise DC volume control unit electronist Parts 0 31st December 2003 10:29 AM
Copyright 1999-2017 diyAudio
