Have on order car amp PPI P900.4 -> 4x100w 4 ohms w/12v, under 0 new....
Old 25th February 2013, 10:56 PM   #11
turbodawg is offline turbodawg
Originally Posted by theAnonymous1 View Post
Ok, curiosity got the best of me. I took mine apart.
Guess what... I was right the first time! The amp is IRS2092 based with one piece per channel.
Power supply fets are AOT460 if that matters to anyone.
Awesome! So what do you think of the implementation....good, bad or ugly? How is the smt fab, board layout, and parts quality? Anything different about it vs. other designs?
Old 26th February 2013, 02:01 PM   #12
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I'm not really qualified to pass judgement on the design, although I see a couple things that don't look right.
Local supply decoupling seems inadequate. There should be something like 330uF-470uF near the output fets for each channel, but the only electrolytics are the two 3300uF bulk caps by the supply transformer. I assume they didn't include them because of space limitations.
The crosstalk is supposedly poor (30dB @ 1kHz?). I forget where I read that, it's not in the manual. There's an input filter that might be partly to blame. The L/R input signals wrap around the same ferrite toroid.
There'se also a few spots with components missing , which makes you ask "why"?
Overall build quality is decent. I guess as long as it works I have no real complaints.
Since I already have the thing apart, I might replace the 10x TL072 with OPA2132.
Old 26th February 2013, 02:09 PM   #13
Pallas is offline Pallas  Pakistan
Maybe they use the same board for the 5-channel variant?
Serious Audio Blog
Old 26th February 2013, 02:28 PM   #14
No, looks like some missing R/C zobel parts.
Old 28th February 2013, 06:27 PM   #15
So, my amp came in, so far it looks pretty heavy and well enough made for $187. Also got the sla battery. Might get a chance to set it up tonight and run it a bit.
Have on order car amp PPI P900.4 -> 4x100w 4 ohms w/12v, under 0 new....Hide this!Advertise here!
AMP 12V 8 ohms output power 30W and very simple kasimo Chip Amps 2 2nd January 2012 06:12 PM
How could I remote turn on a sure 4x100W amp in a car setup? nicoberndt Class D 5 27th October 2010 10:38 AM
12v -> 24v power supply mobyfab Power Supplies 19 8th March 2008 01:11 AM
>>> cheap 50,000uF 60V capacitors here >>> Lubomir Swap Meet 0 1st February 2007 03:36 PM
