Troubleshooting: T-amp with SLA battery, no sound output - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 19th February 2013, 06:54 AM   #11
sounds like a good idea. I appreciate the help
Old 20th July 2013, 01:20 AM   #12
Any one find a solution to this odd problem? Beside using another amp.
I have a variable power supply and match the exact voltage coming for the wall plug. When plugged into the var. PS, the blue lights come on and pulls about 0.16 amps. I can vary the voltage +-1 volt and no sound.
Old 9th February 2014, 04:41 PM   #13
Nruts is offline Nruts  United States
Exactly, same problem here - did anyone resolve this? Was wondering if the forward-biased diodes fixed the issue. I can't seem to figure it out either - even the battery I have should be able to output 12v @ 4A and it won't turn on the speakers (only the blue LED). I haven't tried measuring with a multimeter yet though, but wanted to know if anyone got the Pyle PFA300 working with an external battery...Thanks
Old 11th August 2014, 05:22 PM   #14
Default Series Diode(s) will solve the problem
My setup appears to have the same issues. Controlled the supply voltage on a lab power supply. My unit is fine until the voltage exceeds 11.8 Volts at which point the protection relay within the amp will not close and permit the speaker load to be applied. Under that voltage everything is fine. In my case the battery pack I am using (12.57V charged) will need a diode drop to get me in the range required by the amp. Those will higher voltages will require you to series up your diodes to get the sufficient drop. The diodes are a better solution as they will drop the same voltage regardless of current draw. Please use a power diode rated well over the current rating (@A). On mine there is a solid wire in place of an inductor (L5) on the power input so its a convenient place to add the diode. My board has cut traces and kludge wires all over it. Very poorly made. My boss would beat me if a made something that looked like this. On the other hand its cheap and if it burned up I would laugh not cry. Good luck.
TA2020 Amp and 12V 7Ah SLA Battery?? Leejin Power Supplies 25 10th May 2013 02:17 AM
Troubleshooting sound issues with battery-powered outdoor PA sharevari PA Systems 4 17th June 2012 04:58 PM
SLA battery sounds better than A123? ggking7 Parts 8 4th January 2011 03:30 PM
Cheap SLA Battery w/ charger for SI T-Amp WayneM Class D 6 10th June 2005 05:03 PM
SLA Battery Charger doomsweek Digital Source 2 21st November 2004 10:04 PM
Copyright 1999-2017 diyAudio
